Question on eibach struts and gt500 mounts
Old Mar 17, 2013 | 01:06 PM
blk_on_blk's Avatar
ok guys need a little help here... i drive a 2013 gt 5.0, and recently purchased the eibach sportline springs, and pro strut and shock kit from eibach to, and the gt500 strut mounts... well went to install them today and the back was the breeze, the front is were im having issues, i removed the stock strut with breeze, and went to install the eibach spring and strut with the gt500 mount, and after compressing the spring i noticed the gt500 mount will not fit on the shaft of the strut it goes on but, i cant get it to grab the nut in the middle.... any advice will help out... thanks
Attached Thumbnails Question on eibach struts and gt500 mounts-20130317_112535.jpg
Old Mar 17, 2013 | 01:12 PM
blk_on_blk's Avatar
Old Mar 17, 2013 | 01:22 PM
smitty's Avatar
I think you re-use your stock mounts with the eibach struts
Old Mar 17, 2013 | 01:24 PM
blk_on_blk's Avatar
lol naw these are suppose to work with them... my buddy has a 2012 and same setup and they worked..
Old Mar 17, 2013 | 01:38 PM
JMac's Avatar
My guess... you have the 2011+ Struts (part #35125.840) instead of the 2005-10 Struts (35101.840). IIRC the GT500 Strut mounts only work with the 2005-10 Struts as they have a longer bolt. Using the GT500 Strut mounts has been the answer for how to use the struts that are not 2011+ specific ones.
Assuming I'm right (which I may very well not be), you'll probably have to get 2011+ specific strut mounts or go with the stock ones.
Old Mar 17, 2013 | 02:51 PM
blk_on_blk's Avatar
i order them thru american muscle and looking at eibach web page and typed in the 2013 gt it gave me the part number you listed.... 35125.840 so im assuming those are the ones that american muscle sent me.... that sucks... looks lilke illl be contacting american muscle to see whats up..
Old Mar 17, 2013 | 02:57 PM
blk_on_blk's Avatar
Old Mar 17, 2013 | 03:42 PM
blk_on_blk's Avatar
and i confirmed it on the box is the 35125.840
Old Mar 17, 2013 | 04:12 PM
kn7671's Avatar
You can always take apart the factory strut/spring/mount and re-use your factory mounts, that was the point of the 2010+ specific design.
Old Mar 17, 2013 | 04:16 PM
JPMotorSport's Avatar
Yes. If the car's already apart I would just go this route and return the GT500 mounts...
The stock ones aren't bad and I think they made 2011-2014-specific specs on those Eibach examples vs the 05-10 models...
Old Mar 17, 2013 | 04:34 PM
blk_on_blk's Avatar
yea i think thats what im gonna do.... cause my buddy has a 2012 but he has the 35101 part number...... on his eibach pro kit.... i got a different part number on mine... guessing thats why it wont fit....
Old Mar 17, 2013 | 05:58 PM
JMac's Avatar
This whole thing was very confusing to me while I was researching out my parts list. I was originally going to go with the Eibachs as well but I already had the GT500 mounts (found a good deal) and once I realized the 2011+ specific struts weren't going to work, I ended up going with the Koni STR.Ts which aren't made specifically for the 2011+ Mustangs.
After responding to your post, I ended up driving over to where my car and parts are stored to just to make certain everything is going to fit.
Old Mar 17, 2013 | 07:14 PM
blk_on_blk's Avatar
yea it confused the **** out of me to.... now trying to pull the stock strut mount off is a pita............
Old Mar 21, 2013 | 03:25 PM
06blackvertstang's Avatar
I just want to see your car on sportlines!!!
Good luck with everything else!
Ecostang
Nov 3, 2022 08:50 PM
Last1
Sep 5, 2015 01:23 PM
Mackitude
Aug 17, 2015 04:14 PM
SMBJoshy
Aug 16, 2015 02:48 PM
killaz05
Jul 24, 2015 08:49 AM
