Popping noise - whiteline front sway bar
Old Apr 15, 2013 | 06:36 AM
SlowRiderr's Avatar
Occasionally I hear a popping noise coming from the driver side wheel area when driving slow over uneven ground. I took my wheels off and checked the bolts on the sway bar links. Everything looks fine... maybe one of the end links is bad?
Old Apr 15, 2013 | 12:49 PM
Brandon302's Avatar
Did you happen to take off your struts while doing the install?
Old Apr 15, 2013 | 12:56 PM
11SHELBYGT500's Avatar
Popping noise in rear is from not properly installing sway bar. Ford recommends tightening sway bar bolts while under load. It can be done correctly in the air but its very difficult.
Old Apr 16, 2013 | 05:47 AM
Jay@Hypermotive's Avatar
Former Vendor
Most suspension parts need to be installed underload or you will get some sort of noise.
Old Apr 17, 2013 | 06:10 AM
SlowRiderr's Avatar
This is a front sway bar. Every article and writeup I've seen has people jacking the car up and taking the tires off
Old Apr 17, 2013 | 09:15 AM
Brandon302's Avatar
You can probably put it under load just like the rear, jack the front suspension up and then tighten.
Old Apr 17, 2013 | 07:04 PM
SlowRiderr's Avatar
Thanks for the tip
Old Apr 21, 2013 | 09:48 PM
JPMotorSport's Avatar
You can also use ramps if you can fit underneath...
Old Apr 27, 2013 | 05:29 PM
devildog1679's Avatar
Front sway bar can be installed with the suspension unloaded. Just don't tighten the brackets until you lower onto ramps. The end links can be tighten either way.
Old May 1, 2013 | 07:47 PM
SlowRiderr's Avatar
Thank you! That's what im going to do
Old May 2, 2013 | 05:54 AM
Former Vendor
Correct!
5.M0NSTER
26
Sep 28, 2015 07:11 PM
Mackitude
Aug 17, 2015 04:14 PM
Mackitude
Aug 13, 2015 01:05 PM
Jul 30, 2015 06:47 AM
killaz05
Jul 24, 2015 08:49 AM
