Panhard Bar advice
Old Mar 26, 2017 | 10:25 AM
  #61
Mustang dog's Avatar
I had the Spohn adj UCA with the Delrin bearings, a top notch piece of equipment.
I highly recommend the differential bushing be upgraded to a spherical as well. I ran this with the poly upgraded bushing, and it wasn't near strong enough to alleviate the clunking that was the result of a pivot/poly bushing combination. I have paint marks on the bushing housing on the differential from where the uca was hitting it between shifts. I went back to my BMR poly bushing and zero clunking issues.
Moving forward, if I ever track this car I will put the Spohn back on but not without the diff spherical bearing on the diff side at the same time.
My 2cents
Old Mar 26, 2017 | 12:31 PM
  #62
ElkGroveFordGuy's Avatar
Originally Posted by Jazzman442
What bar do you have?
I have a spohn adjustable pan hard bar.
Panhard Bar - Tubular Adjustable with Poly/Del-Sphere Pivot Joint Combo -
Easy to adjust and silent I have not even thought about it in a long time!
Old Mar 26, 2017 | 02:42 PM
  #63
Ponywars's Avatar
a little off topic but will i need a jounce bumper kit when installing steeda sports with my koni str.t gt500 mounts,its a 1" drop in front and a 1.25 in the rear and i,m going to use an adj panhard bar of course. 2012 gt brembo
Old Mar 26, 2017 | 02:59 PM
  #64
m05fastbackGT's Avatar
If your lowering under 1.5 inches, your OEM jounce stops should be just fine.. When lowering at 1.5 inches and beyond, it's then recommended to upgrade to shorter jounce bumper stops..
Old Mar 26, 2017 | 05:20 PM
  #65
Or take a box cutter and shorten your existing stops.
Old Mar 26, 2017 | 09:26 PM
  #66
Ponywars's Avatar
i was thinking about getting the jounce bump kit as long as i was doing the springs,but if its a waste then i,ll leave the stockers in as i,m not going lower than 1 in front and 1.25 in the rear
Old Mar 26, 2017 | 10:21 PM
  #67
Just as Mustang Dog suggested, you could always just use box cutters to shorten them.. However as I stated earlier, unless you intend to lower your suspension at 1.5 inches and beyond.. You don't need to purchase an aftermarket jounce kit nor cut your "OEM" jounce stops.. As doing so will most definitely be a total waste and unnecessary..
Old Mar 27, 2017 | 07:38 AM
  #68
Jazzman442's Avatar
My 2cents
Is this the bar you are talking about:
http://www.spohn.net/shop/2005-2008-...int-Combo.html
This is the one I am thinking of getting.
The FRPP one is off set for the Track Pack dif cover and I am wondering why?
Old Mar 27, 2017 | 07:52 AM
  #69
No, I was talking about the Spohn Upper control arm. That is for the Spohn panhard bar.
Which is a very nice piece btw. Myself I would go Spherical/ Spherical for the Panhard bar (even for street use) Maybe a bit noisey but much more compliant. (I have Poly/poly right now and no complaints). But I think the Spherical is definately the upgrade I should have made when I was buying everything at once.
The offset is if you have an aftemarket differential cover, they are a bit Thicker and will sometimes rub on the PH bar depending on your setup, Im going with a PH bar relocation bracket .
http://www.americanmuscle.com/bmr-pa...-red-0514.html
Old Mar 27, 2017 | 08:06 AM
  #70
Jazzman442's Avatar
The reason for all this information gathering on a bar is I want one that will be quite and be compliant but keep everything tight and aligned.
Old Mar 27, 2017 | 01:07 PM
  #71
You just might be interested in the Whiteline adjustable PHB..
http://www.americanmuscle.com/whitel...dbar-0514.html
Old Mar 27, 2017 | 09:31 PM
  #72
Jazzman442's Avatar
That was one of the ones I was looking at early on. Then I found the Spohn. Seems everyone likes the one they purchased. Confusing LOL
Old Mar 27, 2017 | 09:58 PM
  #73
Ponywars's Avatar
the whiteline is what i,m going with when i order my steeda sport springs!
Old Mar 28, 2017 | 11:10 AM
  #74
What I don't like about the Spohn, is it still uses poly bushings that require grease.. The Whiteline PHB on the other hand, includes non-poly C-max bushings that not only reduce NVH noise, but most of all doesn't require grease at all.. That alone would be reason enough for making it my preference in choice over the Spohn or any other PHB for that matter..
Old Mar 28, 2017 | 12:33 PM
  #75
tourer's Avatar
According to Ford parts the Track pack option cars have the same struts and shocks as the shelby. I am wondering just how much better these are?
CORRECT!
Old Mar 28, 2017 | 03:27 PM
  #76
Originally Posted by tourer
CORRECT!
So here's my question for you.. Who is the manufacturer of the shocks/struts for the Shelby GT500 What brand are they ?
