Mystery weights above GT LCA axle mounts?
Old Aug 10, 2012 | 04:38 PM
lost won's Avatar
Help.
Anybody know why those weights are bolted to the inside of the lower control arm mounts on the axle? (2012 Mustang GT M82 6 speed with the standard axle). I was looking for a way to attach a shackle to the rear axle to tie the car down to a trailer. Looked at a GT500, and it had some nuts welded in right between the LCA and the axle on the LCA mount. But on my GT there are these (I'm guessing) 2 lb weights bolted on there. I can't imagine what they're doing for us, but don't want to remove them until I know why they're in there.
Thanks.
Old Aug 10, 2012 | 04:40 PM
dmhines's Avatar
NVH reducers.
Old Aug 10, 2012 | 05:29 PM
Womprat's Avatar
canoe anchors, you know, just in case...
Old Aug 12, 2012 | 11:13 AM
908ssp's Avatar
I removed them. Can't say I noticed any difference one way or another just added weight goes against my religion.
Old Aug 12, 2012 | 12:01 PM
From a Ford Engineer that used to post here. He would often mention how different pieces were part of a larger 'system':
lower control arm bracket axle masses
They are there to attenuate axle whine. If you currently notice axle whine in your car in the 45-65mph range, it may increase a bit if you remove the masses. They are one part of a fairly extensive package engineered to address axle whine on the s197 platform.
Old Aug 19, 2012 | 01:20 PM
Ivan 5.0's Avatar
I took mine off. Didn't hear an increase in noise. Dropped ~5 pounds.
Old Jan 19, 2017 | 07:17 PM
Blu13gt's Avatar
Old thread I know. But here are 19x10 MRR-M350 wheels. S550 back spacing.
Rando
Aug 25, 2021 11:12 AM
samjluck
Oct 26, 2015 05:17 PM
Sep 24, 2015 08:15 PM
Sep 10, 2015 12:44 PM
