mixing springs?
Old Mar 29, 2013 | 07:43 AM
TheDivaDanielle's Avatar
Can anyone give a word here for advice? My car is lowered on k springs, and has the brembo valved dampers, as its a brembo car.
I recently installed AR Shelby Torq Thrusts. The front as it sits looks perfect. Its the right ride height. The rear since its a convertible seems to ride about a 1/4" lower than a coupe would.
Problem is that I noticed rubber on the wheel lip this morning and just a hint of grabber blue on the sidewall of the tires. Tires are 295/30R20 and the wheels are 20x10 in back with a 34mm offset. It's very aggressive, and frankly I'm a little surprised AR went with such an aggressive offset.
I will likely change the rear springs to something that'll bring it up a little too avoid bottoming out or potentially damaging the rear 1/4 panels
Will this cause any issue? For a while I was thinking about Steeda sports, and also swapping the dampers, but it's not in the budget right now. I could at least get the Springs, swap the rears for now then get back in there later and swap the dampers along with installing a preassembled front assembly.
Any downside to this?
Another option would be to find a place that could machine like 5mm off of the mounting pad on the rear wheels.
Old Mar 29, 2013 | 08:10 AM
Mr. V's Avatar
I have no experience with what you are describing in mustangs. I have installed mixed springs on friends cars to get the height they wanted. In my experience, if the spring rates are close there won't be any ill effects.
Old Mar 29, 2013 | 08:46 AM
Brandon302's Avatar
I am sure you can go with higher/stiffer springs in the back and be fine, it probably wouldn't handle the greatest because you would have two different types of spring, but I am sure it would be fine.
Old Mar 29, 2013 | 09:08 AM
maybe look for something like this to go under your springs to space them up just a tad
http://www.summitracing.com/parts/gl...FY9DMgod5mcAJw
Old Mar 29, 2013 | 11:33 PM
I'm thinking maybe I'll swap to Steeda Sports (as the fiancee and I are both regularly annoyed by how low the thing is - scraping, bottoming out, etc. which will raise a bit, and maybe I'll try their convertible specific springs.
But I'm curious what the real difference is between the ones that are for a coupe and the ones that are for a convertible.
Old Mar 30, 2013 | 05:45 AM
Brandon302's Avatar
Probably higher pound springs for the convertible since it will weigh more.
Old Mar 30, 2013 | 08:34 AM
mikeyt03's Avatar
The spring rate is different because of the different weight distribution. Buying springs that are made for a vert would fix your issue. Your going to have a rake though.
Old Mar 30, 2013 | 03:40 PM
Thanks Mikey! Steeda it is then...
Old Mar 31, 2013 | 12:21 AM
fgibbs's Avatar
That exactly what I would do..I wonder if they have something smaller?
Old Mar 31, 2013 | 07:16 AM
mikeyt03's Avatar
Also, did you change your bump stops? That could be the issue too.
Old Apr 3, 2013 | 10:30 AM
ConeBoss's Avatar
Having just done rear spring shopping. I would recommend the H&R Race springs for the rear. They are still a progressive spring but they are the heaviest stock style spring I could find. I also run a lot of tire in the rear(315/30/18) and no rubbing for me.
Autotooner
Nov 24, 2017 12:42 PM
Evolution Performance
Northeast
Aug 5, 2016 12:46 PM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
