Notices
Koni Orange vs Yellow
Old 7/8/17, 09:18 PM
  #41
jim010's Avatar
That was an excellent reply. Every informative!
I wiĺl leave sway bars alone.
I have bought the street boss springs and they will be here next week. If the springs and the orange give me what I want, then great! If not, then I go to yellows.
Old 7/9/17, 07:32 AM
  #42
5.M0NSTER's Avatar
Glad to help. Let us know how it works out. I'm curious of your thoughts on your new setup.
Old 7/17/17, 05:18 PM
  #43
jim010's Avatar
Konis are on order and i have the boss springs already (cheap).
I also wanted to take care of a groaning / creaking sound that I figure are the bushings, but ford says the bushings are not serviceable except for the sway bars.
now I don't know exactly where the groaning is coming from, but my service department has a set of rear Shelby control arms for $100 that are take offs.
this a way to go for me?
Old 7/26/17, 11:43 AM
  #44
jim010's Avatar
Soo...
no one can tell me if the rear lca on the Boss , LS or Shelby are stiffer?
I like the idea if polyurethane, but don't feel like greasing them .
Old 7/26/17, 12:09 PM
  #45
THE RED FLASH ------Moderator
m05fastbackGT's Avatar
Received 1,987 Likes on 1,611 Posts
If your looking for non grease lca's.. You might be interested in these..
https://www.cheperformance.com/pages...l-arm-bushings
https://www.americanmuscle.com/white...-lca-0514.html
Old 7/26/17, 07:32 PM
  #46
EF1
EF1's Avatar
Originally Posted by jim010
Soo...
My brembo car had the same lca's as the Shelby. They are supposed to use a higher durometer rubber in the bushings than the stock GT units, but are heavy and not nearly as stiff as poly. I ended up replacing mine with a billet aluminum set from Steeda to reduce wheel hop. I greased them with Mobil 1 synthetic grease when I put them in nearly 2 years ago and haven't touched them since and don't notice any squeaking yet.
Old 7/26/17, 08:13 PM
  #47
5.M0NSTER's Avatar
I left my control arms alone. After the steeda sports, koni yellows and steeda adjustable PH bar my rear axle never once hoped again. And I like it this way
Old 9/25/17, 08:51 AM
  #48
SennaF1's Avatar
Did the OP ever report on his new setup?
The Boss springs are only about 25 lbs/in stiffer than OE GT (123 vs. 148 in front), so they're probably a good match for the STR.T/Orange Koni. In fact, the increase/drop on those springs is so mild that any difference he feels is likely to be mostly from the new struts, rather than the spring.
Old 9/25/17, 05:02 PM
  #49
jim010's Avatar
Yes, I have the springs and the yellows on there. I love it. Next I want to get a stiffer front sway bar.
Old 9/25/17, 06:02 PM
  #50
5.M0NSTER's Avatar
Hey Jim, would love to see more in terms of what your thoughts are with your new setup. Sounds like you might take the sway bar plunge too.
Old 9/25/17, 07:13 PM
  #51
jim010's Avatar
It certainly feels stiffer, which is what I wanted. The front is turned to 3/4 stiff while the back is 1/4 stiff. I discovered that the back too stiff makes it bounce.
and yes, I want stiffer roll bars to reduce roll
