k-springs vs sportlines - any difference in ride quality?
yeah, the clearance is a big trade off in the quest for the perfect stance. the k-springs have very respectable clearance imho. the streets are just too jacked around here to go much lower without scraping up a daily driver. its just tempting to get sportlines because i adore every stang i see with them.
I have the Sportline Kit from AM on my 2010 GT. I gotta say it really puts it on the ground. I love the stance but you gotta be very careful going in and out of parkinglots. The ride is alittle rougher than stock but i love it wouldn't change a thing. I purchased the whole kit springs sway bars and shock/struts.
yeah ill check. i'd assume most people don't run them around here because the roads are sporadically terrible. i'm a lunatic though, i may get a set for the summer and see how they work out.
Currently a Corvette Owner!
I run a tire shop for the United States Army. Simply stand a 20 inch diameter tire next to one of that of a smaller diameter tell me which is taller?? Don't mean to sound like a *****
If I was running lets say a 17" or 18" it would put the car that much closer to the ground with 245/35/20 my exhaust rub when I'm entering parking lots or anything with a slight hump
You may be out of business soon, running a tire shop, but not understanding the difference between a wheel and a tire.
Quit the tire business and put proper diameter tires on your car.
It's not my business it's the army's so hey... I'm talking about wheel diameter forgive me for saying tire my goodness. I like how my ride is set up I really don't have room to put a taller tire without having issues with rubbing. I was just trying to lend advice about the suspension setup having it myself.
Taller tires, especially when they are stock diameters cannot and will not cause rubbing issues. Running very wide tires might, but you'd be way wider than a 245.....
For got the period. I was saying that 245/35/20 is what I'm running. If I was running a smaller WHEEL it would typically make the car slightly low. How ever you could compensate for the smaller wheel by using a taller tire.
I'm lowered on K-Springs on 295's out back and 255's up front, so basically unless you're bagged, you're full of **** and backpedaling.
Either way, your issues stem from improperly choosing a tire that was far too short for the application.
Your exhaust rubs because your tires are too short, and as a side effect of it your car sits closer to the ground.
Sportlines are much better than K-springs as far as ride comfort however, that is a subjective opinion. If you match these up with quality dampers like koni the ride quality will be good. Stock dampers can't really handle the higher springs rate let alone the drop, you'll get the "bouncy" characteristics. K-springs aren't really that great as far as quality (depending on who made them that year for Ford) and performance.
Ok. I can live with that. I didn't choose the tire I bought the wheels and tires from someone as a package deal for 700 bucks when the wear out I might try a taller tire. I like the height and stance as it sits now. Just gotta be careful in parking lots.
#40
