How wide can I go?
Old May 12, 2017 | 12:42 AM
favemistke's Avatar
How wide can I go?
Looking for wider rear tires on my 2012 GT premium. Currently have 245/45/19's all around. Will 275/45's work? Thanks.
Old May 12, 2017 | 07:57 AM
dusman59's Avatar
Depends on wheel width. Go by tire manufacturers data specifications.
Old May 12, 2017 | 08:03 AM
Mr. V's Avatar
Which rims do you have?
Old May 12, 2017 | 08:38 AM
1 Alibi 2's Avatar
According to TireRack, you'll need a rim width of 8.5-10.5" for a 275/45-19 tire.
The tire OD is 28.8", which if taller than your current tire, will change your rear end ratio.
Most likely mess up your speedometer too.
Old May 12, 2017 | 10:32 AM
favemistke's Avatar
Thanks, guys
Old May 12, 2017 | 01:08 PM
ford20's Avatar
Based on the wheels it looks like you have, the tires will probably bulge a little bit, but should be ok. You are pushing it on the size though and I wouldn't go any larger than a 275 on an 8.5" wheel.
Old May 12, 2017 | 08:04 PM
EF1's Avatar
EF1
I run 275's on the stock brembo 19 x 9" wheels at all four corners without any issue. I wouldn't go any wider on the 9" wide wheels and am considering buying a set of 19 x 9.5" wheels. You can fit wider on the rear if you have the right wheels (width and offset).
Old May 13, 2017 | 06:37 PM
Siber Express's Avatar
Actually you should probably run a 275/40 19, pretty close to the same height as the 245's you have on now.
Old May 13, 2017 | 06:50 PM
EF1's Avatar
EF1
The 275 40 19 is almost the same height as the stock 245's, but fills the wheel wells out nicely.
