GT 500 Wheels and Tires. Should steering...
Hey Gang,
I just bought some GT500 SVTPP wheels and tires and put them onto my 2012 GT. They are quite a bit wider that my stock tires and ALOT harder. Which was a surprise since they are considered high performance tires. I would have thought they would be a softer compound.
Anyways, with the wider tires, should I feel a difference in how the car rides or steers?
If so, can someone explain why (besides the obvious size difference)?
I mean what are the dynamics taking place that might make it feel different...other than my imagination. I'm just curious and too lazy to use the Internet on my Google machine.
Thanks.
Thanks.
Hey Gang,
Thanks.
Thanks.
I just did the same wheel/tire swap. Afterwards my car was very "darty". We all know that bigger tires follow rutting , ridges ,etc in pavement but mine was more than that. It only did it while running straight on the road. Driving thru any curves and it went away.
I drove it that way for a week until my springs, shocks and cc plates came in. After i installed my parts I went for a test drive and the darting was almost gone. After alignment it was completely gone. I suspect an alignment to match Ford specs fpr Boss, GT500 etc would help.
I used alignment specs suggestion by suspension shop I dealt with. PM me if you want more info.
Mike
Mike
Hey Gang,
More info on the exact wheels, width, and tire brand, model, and width for the front and rear please, plus what your factory tires and wheels were.
Yes, you are right, there are many things that can change the dynamics of how a car drives, but we really need to understand what you have now to explain what will have changed.
I used to have stock 18x8 with 235/50/18 P Zero Nero.
Now have rear 285/35/20 and front 265/40/19 Goodyear Eagle F1 Supercar G2.
I am definitely rethinking keeping this wheelset.
It's unsafe to drive aggressively under those conditions, but for getting around they are fine. I went all winter on summer tires, it's not like they won't work at all if that's what your thinking
1 Post
if you are going from 18s to 19s, then yes you will feel a substantial difference. i use 18s for winter wheels and it is a much smoother ride. then it is noticeably harder as you say when I switch to the 19s in the spring. just make sure you don't have the summer only tires on there. If you do and its under 40 degrees, it will feel a lot harder. I wouldn't feel safe driving summer tires in winter though. Just because others do it doesn't make it any safer.
Mike
Mike
1 Post
There are a couple of down sides to using these tires and wheels.
1. Cost of replacement tires.
2. Availability of tires in your cars speed range. You really don't need 186+ MPH tires on most Mustangs, so why pay more just for the bragging rights.
3. By using different size tires front and rear, you can no longer rotate the tires. Tire manufactures cut their mileage warranties in half because of the inability to rotate the tires.
I'm sure you and other members can add to this list. I think you would have been better served with 18" wheels all around and the same size tires on all for corners.
If you did for looks, you succeeded, the car does look good with those tires and wheels.
