Can I safetly paint my Brembo front rotor hats?
Old May 9, 2015 | 10:26 AM
PJRManagement's Avatar
Currently a Corvette Owner!
Hi, there. Has any one successfully painted Brembo front rotor hats? The center section. I have the 14" rotors in front. I want to paint the hats matt-black. But I don't know if the paint can withstand the heat. Has any one done this? If so, which brand of paint will stay on there well?
Old May 15, 2015 | 09:22 AM
Horspla's Avatar
I painted my stock brakes hats and calipers and have had no issues. I used a good heat resistant paint. I suspect if I really nuked the brakes a lot, as in tracking the car, the paint would probably suffer but then again, I don't think any paint is really going to hold up real well under those conditions.
John
Old May 15, 2015 | 09:36 AM
logical's Avatar
For matte black, you could probably use what is marketed as BBQ paint. It's designed for high heat
Old May 15, 2015 | 11:10 AM
Jazzman442's Avatar
Really High Heat Paint works Great. Prepping is the key.
Old May 15, 2015 | 07:21 PM
Thanks, guys. I read on a Corvette forum that prep work with brake cleaner, paint thinner, and acetone is good. And Duplicolor brand heat paint is good.
Old May 15, 2015 | 09:35 PM
houtex's Avatar
I used VHT black caliper paint on the rotors and calipers. Taped off the faces, shot the hats and the edges of the rotors.
Still lookin' good after a year or so now. In case that helps.
Just did the instructions on the calipers, btw, just shot it with VHT brake cleaner, little plastic brush to scrub it a little, shot it again, wiped it down with them blue shop rags, then shot the caliper. Turned out great, I think!
Old May 18, 2015 | 01:25 PM
Thanks, houtex!
Fords4Ever
Oct 30, 2015 09:07 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
M3hunter
Sep 10, 2015 09:26 AM
earl610
Sep 6, 2015 05:48 PM
