which are the best sway bars for neutral handling
Old May 12, 2013 | 10:20 AM
M3hunter's Avatar
Question which are the best sway bars for neutral handling
Hi guys
Which are the best sway bars for close to neutral handling at the track (no understeer, no body roll neither), for a '10-'14 GT?. Specify if you are staggered or non staggered.
Old Jun 5, 2013 | 09:51 PM
lost won's Avatar
Originally Posted by M3hunter
Hi guys
Good luck. no understeer and no body roll? bars alone won't get you there.
Old Jun 7, 2013 | 08:00 AM
lsxjunkie's Avatar
Hi guys
Adjustable ones. Adjustable front and rear sways will allow you to dial in the under/oversteer nature you're most comfortable with.
Old Jun 9, 2013 | 01:07 PM
MARZ's Avatar
Swamp Donkey Aficionado
This. Aftermarket sway bars will have a negligible impact on the handling metrics OP outlined above at best. Personally speaking, while the Koni STR.T shocks and struts are a huge improvement over the stock parts, they're still very soft. I just swapped out my Koni STR.T dampers for a set of 2013-14 GT500 Bilstein shocks and struts (stuck in sport mode because I don't have a damper module) and they've eliminated virtually all the body roll my car exhibited even with the Koni STR.Ts in place. You'd probably be better off investing in a set of adjustable shocks and struts such as Koni Sports (aka "yellows") or FRPP adjustable dampers (I've driven a car with these and they're magnificent). That way, you can adjust them according to whether you're on a road course, drag strip or on the street. I sure wish I had the ability to soften my dampers just a bit...
Old Jun 9, 2013 | 01:21 PM
I wondered about that since the GT500 dampers are for a heavier front end.
Old Jun 9, 2013 | 06:52 PM
MARZ's Avatar
Hey Charlie, so far, so good with the GT500 Bilsteins. Handling has improved dramatically and the ride quality, though noticeably more taut than with the Koni STR.T dampers, isn't all that bad. I just wish I had the ability to swap them over to "normal" when the tarmac got rough. The one odd thing I've noticed since installing the Bilsteins is that my car appears to sit higher, even when using the same FRPP springs I had on my car previously.
NC14GT
Sep 10, 2017 04:47 PM
GeoWett
Sep 30, 2015 06:40 AM
RoushRS3
Sep 29, 2015 08:03 PM
Evil_Capri
Sep 25, 2015 12:56 PM
Ray11
Sep 25, 2015 12:43 PM
