Adjustable Suspension
So ever since they announced the GT500s suspension and it became obvious I didn't have the patience to wait for one I have been looking at suspensions that are close to as versatile as the GT500s, but this is the best I have come up with, what is all your guys opinions on it? Do you know of any others, or better ones? Would this kit be all I need for suspension? I am a complete n00b when it comes to suspension.
http://www.ridetech.com/store/2005-2...g-level-2.html
What are your goals?
This kit you've linked to is an air-ride system, which is usually reserved for show cars that like to literally slam the chassis to the ground when at shows, then raise the car up to drive it around. It's not a good handling option -- in fact it will likely severely degrade it.
If you value handling, talk to Sam Strano and he'll set you up with an adjustable suspension package. You have options like adjustable shocks/struts or fully adjustable coilovers.
Yea, as I read more I started to figure out I sounded like an *** when posting about an air ride. I am looking for something that is easily adjustable from daily driver use to track use. I love that the new GT500 has a button you just push for that with preset stiffness. Would like something nearly as easy and requires little thought. I don't want to have to throw the car on a rack in before going to the track and after done at the track basically.
I run Koni Yellow adjustable shocks and struts. They are not adjustable from in the car, but it's just a matter of turning a dial on top of the shock to change rebound. It's a nice setup. You can go from comfortable "full soft" to much stiffer settings for spirited driving, track use, etc.
I don't know if there are any aftermarket options like that for us. I know a buddy of mine runs a nice Tien system on his 370Z that is electronically adjustable from in cockpit.
Originally Posted by LostGeographer
Do I need an associates in vehicle suspension to know how to use them? Following that FRPP thread with adjustable suspension made my head nearly explode.
Originally Posted by m4a1mustang
Like I said, give sam strano a call and tell him what you're looking for. He will put together a setup for you.
![Rollinglaugh](https://themustangsource.com/forums/images/smilies/rollinglaugh.gif)
Sam is an SCCA National Champ with a shop in PA. He takes his time to work with you and make sure you understand EVERYTHING you're buying or thinking about buying from him, or anyone else. He's a great guy with great service and competitive pricing.
Not knocking Steeda, as I have found their service fantastic when it comes to my tunes, but Sam is my suspension guy and always will be as long as he's in business. He's hardly a one-man reputation.
That's too bad. All of my many interactions with him have been great.
