2014 Shelby GT500 6 piston Brembo brakes review
Old Mar 17, 2015 | 06:25 PM
pressman43's Avatar
Originally Posted by Astenax
I have Sve Drift wheels and they are 19/9.5/+35 off set i believe. I can tell you that they hardly clear these beasts, these brakes are "Huge" especialy the rotors!
What size rubber are you running on your SVE's?
Old Mar 18, 2015 | 10:54 AM
Astenax's Avatar
275/45/19 Hankook ventus evo v12
Old Mar 21, 2015 | 01:03 PM
pressman43's Avatar
Thanks. I'm looking at the Drift's but not sure if I want to stick with the 275/35/19's that come with the kit from LMR or go with 285/35/19's.
Old Mar 21, 2015 | 06:24 PM
Plim's Avatar
Originally Posted by SpectreH
If I recall, they were putting the GT500 up against a ZL1...while initially faster, the GT500 was only good for one lap around the track they were using before the brakes were fading bad. Another lap or two and the ZL1 would pass it. They noted the ZL1's brakes had proper cooling ducts while the GT500 did not. Of course in a straight line, the ZL1 did not stand a chance...662hp vs 580hp.
That was indeed what they had to say!
Old Mar 21, 2015 | 06:48 PM
SpectreH's Avatar
I guess my memory is still good....at least for important things.
Old Mar 22, 2015 | 06:46 AM
dmichaels's Avatar
The 4 or 6 piston brembos paired with 3" cooling ducts, high temp fluid like Motul RBF600 or Castrol SRF plus a set of track pads like Carbotech XP20 or Pagid RS29 will last all day and provide incredible stopping power. That setup will suffice until you run full slicks and have significant power mods and are driving with the advanced groups. My brembos are still doing the trick for me.
Old Mar 22, 2015 | 06:20 PM
5.M0NSTER's Avatar
I second this. I have no cooling (putting on GT500 shields for this season), I use XP10s with RBF600 fluid and I run in intermediate groups with no fade issues. The factory 4-piston Brembos are actually really good brakes.
I can only imagine how good the 6-piston setup is!
Old Mar 31, 2015 | 03:37 PM
Stevedotmil's Avatar
I agree as well. The Hawk HP+ pads and ATE Super Blue with stock everything else held up awesome after 16 laps at Hockenheimring. No fade at all.
Old May 12, 2015 | 02:21 AM
Astenax's Avatar
Im doing 285/35's for sure next set of tires! These Brembos need wide rubber up front to stop hard! Ive found the 275's in the front to be very good. Big front brakes are worthless without wide front tires, they add to the grip! Thanks for the post!
Old May 12, 2015 | 02:28 AM
Astenax's Avatar
Key word here are better ( cooling and fluid ). I can tell you that these brakes are serious and bite hard. You have to have them to know this I guess, but the people that talk down on these brakes are fools because I can tell you that they are bad ***** f@#$ers! Thanks for the post!
Old May 12, 2015 | 02:36 AM
Astenax's Avatar
I agree! The 4 pots do fit a smaller lighter wheel and do have there benefits but the 6 pots will bite harder and allow a faster entry to the turn no? So weight vs later braking, lol take your pick lol!
Old May 12, 2015 | 02:51 AM
Astenax's Avatar
I had Hawk HPS pads on my stock base GT Mustang brakes and they stopped my Stang 10 times better than the stock pads. I hated the squeal from the Hawks though and these Brembos are quiet and would clobber the stopping power of my base brakes+HPS pads in a second lol! For $1500 these 6 pistons they are worth the upgrade, but if you don't have the coin and can stand the squeal sound of the HPS they do work! I have a set of front HPS for the stockies that have less than 500 miles on them that I will sell for $50 if any body wants to pick them up in Cali! Im keeping the rears but hit me up! I can only imagine the HPS pads on my 6 piston clamps lol ****! but I cant stand the squeal lol!
Old May 12, 2015 | 02:58 AM
Astenax's Avatar
Thanks for all the comments guys! I work a 70 hour work week and some times it takes me a long time to reply! I love my Mustang!
Old May 13, 2015 | 05:19 PM
dmichaels's Avatar
Won't necessarily bite harder overall - I could lock up my wheels with mine, no problem, for a bunch of laps at least. But the 6-pistons might require less pedal pressure to do so, and also utilize the larger rotor, so more surface area for heat dissipation.
So I guess I sort of agree - you could probably brake a bit deeper more easily for longer sessions without fade.
Anyways, awesome setup. I am very stuck to 18" wheels though due to tire availability/choice and cost. Lots of take-off slicks for very good prices with the 18's, but I've heard there are a couple 18" wheels that the 6-pistons fit under... might be on the list for down the road...
Old Dec 7, 2017 | 11:55 PM
trackpack13gt's Avatar
What brake lines did you use oem gt500 or aftermarket?
Scothew
Curated Content Articles 2005-2009 Youtube & Photo Gallery
Aug 14, 2023 03:37 PM
Detroit Steel
Jan 17, 2016 08:06 AM
Jul 30, 2015 06:47 AM
Coyote5-0
Jul 17, 2015 03:47 PM
