2011 GT rear brakes overheating on track days
I will try this for the next time I'm out. This might actually be at the Nurburgring though so I may be in Sport for the first lap to guage the corner speeds. Then if I'm comfortable I will try it with full off. I really got a great feel for the LSD pushing my through the turns and helping the rear end rotate with throttle input. Fun times. I'm super addicted now. I may get some Carbotech rears when I upgrade to the Steeda rear larger kit. I am debating on either the Ford Racing ducting that goes where I have no lower fogs or the JLT kit. Thoughts?
I like the Ford Racing kit because it's in a stock location and proven. I like the JLT because it's cost effective and I can get the blacked out inlets so you won't tell it's there really. But then again I will have to cut holes in my car versus using space that isn't being used and it's reversable. It probably won't ever be reversed but the option is nice to have.
^ This. If will feel slower, but in fact you will get better lap times driving full off if you do it right. Stability control brake interventions on outside wheels really slow you down and add time to your laps. Even if you slide a little in full off, you can maintain your momentum and manage slide with throttle/steering. Managing weight transfer is key, and Traction Control as well as Stability Control don't let you do that.
Currently a Corvette Owner!
^ This is my plan for my next track day in May. So...knowing all that we know now regarding TC/SC chewing up rear brakes on the track...I have a question. With TC/SC fully off, do you think I will still need to remove the rear dust shields? I'd rather not if I don't need to. Thoughts...?
This is what gave me the idea of using the fog light housings. Another track rat at work. DMichaels.
https://themustangsource.com/forums/...ustang-524860/
I was having to manage the weight of the car the whole time. It was always on my mind. I guess this is a good thing so when my car doesn't dip and lift with better suspension I will still be in the habit of thinking about the weight transfer and not just making the corner.
Last year I got a great handle of weight transfer. I noticed that if I went "hot" into a 110deg corner coming off the main straight the car would over-steer just before the apex. At first my reaction was to counter steer, which caused me to loose momentum and take a wider line than I initially intended. On later laps I realised that if roll onto the throttle 25% at that moment, I transfer the weight to the back, my tires bite down, and I come out of the corner on a better line with more speed. That once corner alone helped me shave 0.5s off my lap thanks to better weight transfer management
My advice would be to get some solid rear pads which can take more heat than the ~800 or so degrees the stock pads are good for. I'm very excited to put Carbotech XP8s in the back and rest assured that I can safety go up to 1350F before the pads cook. The person at Carbotech I spoke with said that with XP8s and system off I should not even approach the 1350 mark in the back unless there is a mechanical problem. So my plan is to leave the dust shields in, but upgrade the pads to handle more heat. I worry about rocks and stones getting in there with the shields off.
I wish they made Ford Racing cooling shields for the back.
Missed this thread the past couple days... I have a few bits of input:
1. Rear brake cooling - I rigged up rear cooling late last season. It seemed to work fairly well, although I also had a bend axle all season, so I'm expecting better rear brake temps this season now that I have a near right rear axle. But some pictures of the rear brake cooling "beta" setup I have are below. At the inlet I do have a scoop I'd like to note
In regards to the point made by Tod about TC in sport mode - yes, that absolutely destroys the rear pads. I can't drive in Sport mode anymore (at the track) as it interferes far too much, pulsing the rear brakes excessively. I do use it in the wet though since the car is so tail happy...
But I do recommend traction control fully off, and then you should have no rear brake issues. I'm about the only Mustang guy I've seen that had chronic rear brake issues, but as noted above, I think I finally figured out root cause. The stupid bent axle... Anxious to get out and try the car with straight axles on April 6th!
I've also got a set of Carbotech pads (actually a couple sets that I sourced for cheap) that will be tried out this year. Swapping front pads is no big deal, but the rears really are a huge pain, so I like to keep a pad compound like the XP8 so there is no need to swap for daily driving.
No you're not the only one who has experienced rear brake problems at the track. I too have had rear brake issues. Cooked my rear brakes 2 track sessions ago as well as boiling the brake fluid.
I had been running with the traction control off but not fully defeated.
Since those track days, I have upgraded my brake pads to carbotech Xp-10/8, Ford racing brake cooling ducts, and motul 600 racing brake fluid.
I will put all that new stuff to use in the first week of April at the track.
Brake cooling ducts for the front with XP20's and XP10 rears was an experience this past weekend. No brake issues what so ever, however I finally got diff puke, not sure if that was a function of the better brakes causing more heat in the diff or not.
Put some sort of catch can on the diff housing instead of the pressure relief valve and that should keep the diff from spewing fluid
Then it's on to the next weakest link! Fortunately the cars seem robust overall but there are certainly areas for improvement.
Revisiting this, friends. Had my track day yesterday, and all went great. However, I did not do what I said I would do. I did try TC/SC all the way off...hated it. Went back to Sport Mode, call me a baby, but I am much faster in Sport Mode. Also, I performed a rear brake upgrade two weeks ago. You can read all about it in my newly posted thread on TMS: https://themustangsource.com/forums/...8/#post6926383
To summarize, I installed 2014 GT500 rear rotors (13.8" compared to our GT/Boss 11.8"). I re-used my existing calipers, pads, and dust shields. Very economical upgrade, brakes stayed strong all day at the track. I think I've finally got this rear brake issue fixed (I hope!!).
Hey Pete, how and in what mode you drive is completely up to you. There are no trophy's for track days, there is no medals, and if we do things right we get to keep the car shiny side up and drive it home in the same condition we started. By all means, drive in whatever mode makes you comfortable.
I work for a company which makes brake modulation systems, and we work with OEMs to offer "tack mode" or "sport mode" tuning for stability and traction control. I'm glad to hear that people like it and use it the way it was intended
Glad you got a chance to enjoy a great track day, and your braking performance was all there
