19" drag radials.
Old Sep 6, 2014 | 06:52 PM
KonaBlueStang's Avatar
19" drag radials.
Looking at new rear tires for my gt. Steeda tuned and ever since been needing more traction. Stock brembo suspension and wheels. What are some practical options?
Old Sep 6, 2014 | 09:28 PM
KushBandit's Avatar
From what I've read, no one makes a drag radial from the brembo rims. The closest you will find are Toyo R888, but that's a road race tire.
Mickey Thompson and Nitto make 19" Drag Radials, but they're too wide for the stock brembo rims. I think they require a 10" wide rim if I remember correctly.
If you're planning on high friction launches, like what drag radials are made for, consider a rear end brace or welding your axle tubes. These 8.8" rears like to twist the tubes which tends to push the driver side tire forward into the wheel-well.
Old Sep 7, 2014 | 09:20 AM
Jazzman442's Avatar
Even on the Track Pack Rears? I have read that they are different and are made stronger?
Old Sep 7, 2014 | 10:59 AM
Stevedotmil's Avatar
They are different in that they contain different guts because of the Torsen in there and the exterior paint. Other than that they are the same housing.
Old Sep 7, 2014 | 07:21 PM
KushBandit's Avatar
The only thing the "Track Pack" rear has is a Torsen differential, which is designed for cornering. Axles and axle housing are the same.
The stock differential is better than the Torsen diff. for drag racing.
Old Sep 7, 2014 | 09:22 PM
Jazzman442's Avatar
KushBandit, Thankx for Clearing that up. I read that they were alot different on another forum.
Old Sep 8, 2014 | 05:47 AM
Jazzman442's Avatar
Wont a tire like these:
http://www.tirerack.com/tires/tires....R9A6&tab=Specs
Work on our 19" rims? Trying to learn my self as I want to get the New 19" track pack wheels in Black for the track.
Old Sep 9, 2014 | 06:19 AM
Coyote5-0's Avatar
Good question, will those work???
Old Sep 9, 2014 | 08:43 AM
5.M0NSTER's Avatar
That tire will fit just fine. Only thing is you're loosing quite a bit of tire diameter. But if you don't care about speedometer being off, or loosing a few MPH in each gear it would work on a track.
Old Sep 9, 2014 | 09:22 AM
Coyote5-0's Avatar
hmmm I've got 3.31's so it probably wouldn't affect me all that much. Super expensive tho.
Old Sep 12, 2014 | 01:10 PM
awoychosky123's Avatar
I would go for it
Old Sep 12, 2014 | 01:50 PM
SSStang's Avatar
Those are a road race/ auto cross tire not drag racing.
Sep 30, 2015 07:02 PM
YepItsGreen
Sep 13, 2015 12:32 AM
Cdvision
Sep 5, 2015 05:22 PM
Detroit Steel
Aug 21, 2015 11:09 AM
