05-10 Springs/Shocks/Struts/LCAs on 2013 GT?
Old May 29, 2014 | 04:22 PM
RhythmsDJs's Avatar
I have searched and not found any concrete information about entire older setups on newer GTs. I have a connection on getting 05-10 Eibach Sportline springs, Steeda Pro/Action Shocks/Struts, Steeda LCAs and BMR Relo Brackets and Steeda Adj. Panhard Bar for an unbeatable price used. I know there's always questions about wear and residual life of the parts but having checked out all those things, I'm comfortable with the deal.
My question is this, can anyone comment on these parts being installed on a 2013 GT non-brembo? Is there anything not compatable? I know I will need GT500 strut mounts for this to work, but is there anything else that I'm not thinking about? Also, since these parts were optimized for the 05-10 is there any reason not to use them on a 2013 or are they essentially the same as the parts for the 2013?
Any comments or advice is much appreciated.
Thanks!
Old May 29, 2014 | 05:22 PM
jp1seattle's Avatar
The LCA's and relo brackets should be the same as well as the PHB. (05-14)
As long as you have the gt500 mounts and the 05-10 struts, you'll be good to go on the shock/strut/spring install.
Old May 30, 2014 | 08:38 AM
RhythmsDJs's Avatar
Thanks, I appreciate that. I'm assuming the valving is the same between the different years of shocks/struts, just the overall dimensions are different. Is that correct?
Rando
Aug 25, 2021 11:12 AM
MustangMan13
Nov 12, 2015 09:55 AM
UOP Shadow
Sep 27, 2015 07:24 AM
BackroadGT
V6 Performance Mods
Sep 22, 2015 07:13 PM
