2012-2013 BOSS 302
Track wheels?
Old Nov 24, 2012 | 11:21 AM
mattlqx's Avatar
Track wheels?
Do you have an additional set of wheels dedicated to the track? Are you running different than stock sizes? What kind of rubber?
I'd like to get a dedicated set of wheels for the track since the stock size tires are so **** expensive, but I'm not sure I'd be saving that much money overall.
Old Nov 24, 2012 | 11:40 AM
LindsayEOD's Avatar
I do. I have Forgestar F14s, 19x9 and 19x10, with Michelin Pilot Super Sports in 265/40 and 295/35. This setup isnt what I would call cheap though.
Old Nov 24, 2012 | 01:47 PM
Brandon302's Avatar
Go with TSW's if you like the look of them, I think the cheapest I have seen them for is 275 for 18's, also get 18's because the tires are cheaper.
Old Nov 24, 2012 | 02:17 PM
BlackMamba03's Avatar
Go with 18's. More choices and less expensive for the most part. I'm thinking of going with the Boss 302R wheels myself.
Old Nov 24, 2012 | 09:20 PM
Grant 302's Avatar
I have the same except in 265/35 and 295/30 with the F14s in matte black. I got the lower profile for the track. They're a little short for the street.
Old Nov 24, 2012 | 10:01 PM
PJRManagement's Avatar
Currently a Corvette Owner!
Hey Lindsay. I have the same size wheels as you (19x9F, 19x10R). But I run 255/40 F and 285/35 R. I won't need new rubber for at least another 6-12 months. But I've wondered how going up one width size (like you did) will affect things...sidewall budge, NVH, street comfort vs. track performance, looks, etc. What can you tell me please? Do you have close-up pics?
Old Nov 25, 2012 | 05:41 AM
LindsayEOD's Avatar
I sent you a PM PJRManagement
Old Dec 11, 2012 | 10:55 PM
SlowRiderr's Avatar
I have a stock 12 GT. Can anyone make a suggestion on a budget wheel and tire setup? I don't mind buying used... and im not too concerned with appearance. This will be for track only
Old Dec 11, 2012 | 11:47 PM
DD GT3 RD's Avatar
^ Forgestar and hankook rs3
Old Dec 13, 2012 | 02:49 PM
Jza1736's Avatar
I find the nitto nt01 and the kooks rs3 to be almost the same price. Why would you go With the rs3 vs the nitto's? Any links to cheap rubber prices?
Old Dec 15, 2012 | 12:27 AM
DD GT3 RD's Avatar
Nt01 is an R compound, and I don't switch wheels for the track. So daily driving the NT01 they will heat cycle out cause they are R comps I believe. Otherwise no reason.
Old Dec 16, 2012 | 02:42 PM
mattlqx's Avatar
By heat cycle out you mean will wear out because of cycles rather than tread depth by miles?
Old Dec 19, 2012 | 11:39 PM
DD GT3 RD's Avatar
Correct. R compound tires get a certain amount of heat cycles to my knowledge. I don't have much experience with them, just the ps cups that came on my gt3 which lasted about 2500miles. But my buddy had r888 with plenty of depth but had no grip from being heat cycles too many times. The compound gets hard from heating up and cooling down
Old Dec 20, 2012 | 01:37 AM
UnrealFord's Avatar
Interesting, I didn't know that. Thanks
Old Dec 20, 2012 | 12:06 PM
CaptDistraction's Avatar
I'm using some cheap MB 18x9.5's with continental tire used race tires "conti scrubs". They take a bit to warm up, but are very sticky once warm and cheap.
The wheels cost me $400 for the set, and the tires usually are around $300 or less and I get about 12-20 sessions out of them depending on camber settings. I also have a bunch of pirelli pzero "scrub" tires in 275 and 305 widths that I'm going to try next year, which are stickier but don't last as long.
Depending on your comfort level on the car, I'd get the wheels and start with street rubber and get the car to as fast as you feel you can go with the tire, then move to a stickier compound. Starting with too much grip can cover up a lot of speed-killing mistakes and stunt driver development. Whole speed/control, slow is fast zen type stuff.
Old Dec 20, 2012 | 12:40 PM
Based on what I've read, tracking your car bone stock to get a 'baseline' is a smart approach. Then you can get to that set-up's limits on speed, cornering, turn-in, understeer, oversteer, braking, etc. Then you can improve the bits you want to, at your own pace. That's how I did it, and I'm glad I did.
Old Dec 20, 2012 | 12:42 PM
Every now and then I'll do a session or two on street tires to "humble" myself, and fix any bad habits (moving my hands into turn-in too quickly and too late is an often one I catch myself doing.)
Old Dec 20, 2012 | 02:22 PM
For now, I still track on street tires...granted they are max-performance-summer Contis. Only 3-4 track days per year, I can't afford the $$ for dedicated track wheels or track tires. I wish I could!
Old Dec 20, 2012 | 03:20 PM
Grant 302's Avatar
If you get the rims used and takeoff rubber, I think it can be pretty economical...especially if your street set is on the expensive side.
Old Dec 20, 2012 | 05:44 PM
Track video from this past Sunday, with street Conti DW Summer (F-255/40, R-285/35):
https://themustangsource.com/f660/ne...2012-a-516725/
They howl when pushed, but perform pretty good.
