Track Temps - Cool Tech LLC Update
#82
Originally Posted by 06GT
Wow, great info, and easy solution. Thanks for the honesty and integrity in your results!
#83
Originally Posted by cloud9
The best part of the day was that I think for all intents and purposes I have found the solution to our cooling issue, but more importantly...
Pretty cool cooling mod
Uploaded with ImageShack.us
I ran about half of my laps in the 130's with a low lap time of 138.92
That is so freaking cool!!!!! Congratulations.
#84
Kendall,
Do you have one of your Bosses set up as a control (bone stock grill, etc.)? It would be nice to be sure that it is overheating at your location, ambient temp, etc. (as we would expect it too).
In the very first session all 3 cars overheated. Temp in 90's, 4500 elevation and intermediate to advanced drivers. each car was seeing 240-250 water temps. Totally non-functional. (Note: We were running the full track and we were on the track with Ford GTs.) We had a few engineers from a certain auto company present and supporting our Ford GT event (which we crashed with the Boss's) and it was they that said to pull the grill off. After the first one, removing the grill takes literall about 3-minutes to remove. There's one tricky tab on each side that requires a screwdraiver to coax into releasing and that's it! Re-install takes about 2-minutes. Keep in mind all of this effort is less than it talkes to adjust tire temps!!
FORD -YOU HAVE GIVEN US A GREAT, GREAT CAR!!!!!!!!!!!!!!!!!!!!!!!!!!
Throughout the day, I was encouaging many Ford GT owners to go take the Boss out. Keep in mind that most of these guys have multiple exotic cars - either past or present. WITHOUT EXCEPTION, each of these guys was simply blown away with the Boss. As we became more comfortable with the track, at any given time the Bosses were tracking in the midst of the GT's. The long straight was no contast - the GT's would blow right past, but in the twisties, the Boss was MARVELOUS!!!
GO TAKE YOU BOSS TO A TRACK! YOU WILL NEVER REGRET IT!!! DO IT! (Yes, I'm shouting at you!!!) LOL
#85
I agree. Would totally buy from these guys in the future very, very (did I say, "very"?) impressed.
We will definitely keep the Forum posted - and continue to appreciate all of your insight!!
#87
I do not have a vid (or even good pics) but remove the four plastic pins in the front of the grille on top, then the four pins on the black cover and remove it. Then removed the two bolts on top between the headlight and grille.
Then you will see six tabs on the bottom and two on each side. I started by lifting upward on the bottom tabs and pulling the grille out a little bit but the tabs do not clear the hold downs at this point. I did this since the side tabs are a tad more difficult to release and it helped by not having them snap back in place as you go.
Anyway pull the two side tabs toward the center of the car and pull the grille forward. One side is off now go to the other side and do the same then release the bottom six tabs fully and you are done. Anyone have better info please add.
Bottom two middle tabs looking down. If you blow up the picture above you will see what I mean by unhooking the tabs.
#88
Are we saying it is a good idea to remove the grill when tracking regardless of ambient temp?
Or, remove the grill when it above 90 F?
Or, perhaps , it seems, do we not have enough information yet to make the call at what temp we remove the grill?
Great Stuff Guys!
Great Stuff Guys!
#90
Thanks Scott. I guess that will be something I will consider next year if required. I've not had an overheating situation in my two track outings this summer and my next track day is the day before turkey day, so ambient will be in the 60's.
There will be many more solutions to this issue by then, maybe something from Ford.
My immediate concern is damage to the cooling fins due to rubber marbles at high speed entering the lower inlet. I either need to put in a shield or stay out of traffic.
#91
That is why I am ordering and modding a second grille, so far no damage on the bottom. I posted about it on BMO. Link about halfway down This should also answer your question Chris, if not needed leave it alone or take the risks. I will try to open every bit I can on the donor grille and see what happens. The light part and the bars that are enclosed up top and the sides. With my lame driving this should be good enough for now.
#92
1 Post
Thanks guys it was really cool. I was on a mission so was pretty thrilled it worked out. Scott's writeup on the removal is excellent. As far as temps to removethe grills, it is hard to say. I was starting to get hot in the upper 70s yesterday which it's never done. With the grille out I was running around 230 with 86* ambient I really think my main issue was the lower condenser fins being so bent they were blocking airflow. I ordered a fin comb and will get them straightened. I will be testing a more open grille design at BIR 9/9-9/11.
#93
Have you checked the coolant level since it cooled down?
#94
I had an Agent 47 grill in my 06 GT. All though it did have fog lights, the rest of the grill was wide open. They used steel mesh (expanded metal) for the grill. Let all kinds of air through it, but still gave protection to the radiator. I could see using this style of a grill in the Boss. Maybe they will make a grill in the future?
#96
1 Post
Are you sure it wasn't air in the system? After draining all the water, you may have had a big air bubble in the block. Usually after a good thrashing, you purge all the air but then your coolant will be a little low.
The temperature dropoff after pulling the grille was so dramatic, that airflow has to be the issue. Ambient temps were about 5 degrees hotter and the car ran 15-20 degrees cooler!
#97
If you don't mind cutting the grille up you can do the fake light drilling mod but since the grille removes quickly that just may be an easier way to go. Remember you will take a risk of damage running without it.
Gary, on your condenser fins, it may be time to look into some kind of lower protection for street and track without restricting air flow
#98
