Notices
2012-2013 BOSS 302
track key question
Old 2/11/12, 07:05 PM
heylilcobra's Avatar
track key question
i got the track key installed today ,but i cannot get the lopey idle to come on .i let the car set in neutral for a good 20 minutes ildling .no codes any ideas.?
Old 2/11/12, 07:07 PM
MyStang2010GB's Avatar
It's a check box when they download the software. I'd take it back in and have them ensure it was programmed
Old 2/11/12, 08:48 PM
nota4re's Avatar
It will NEVER come on while the car is stationary. If you had done you test and then rolled forward a little, it probably would have come on. When it switches into this mode it chimes once and displays "Track key ENGINE enabled"
Old 2/11/12, 09:01 PM
SoCalBoss's Avatar
The instructions say it won't come on if the car sits at idle. I could get mine to kick in once it's warmed up and blipping the throttle while in neutral.
From page 4 of the track key instructions (http://www.fordracingparts.com/track...ions%201.0.pdf)
For lopey idle to be enabled, three conditions must first be satisfied. The first condition is that 130 seconds must have elapsed since the engine coolant temperature reached 170 °F (77 °C) while the engine is running. The second condition is that the engine must not currently be idling (Note that it is sufficient just to rev it up in neutral or drive away once the other conditions have been met and lopey idle mode will be enabled). The third condition is that there must not be any detected failures of engine control related sensors or actuators. When all these conditions are met, the instrument cluster will make a "ding" sound and the message center will display "TRACKEY IDLE ENABLED".
Old 2/12/12, 11:11 AM
black_bullitt's Avatar
Not true. I had some guys asking about TK at the first car show I was at after getting it installed, and I turned the car on, let it idle for a bit, tapped the gas and it enabled TK Engine. Got a lot of comments from the guys after it went from the smooth stock idle into the lopey idle.
Old 2/12/12, 12:34 PM
96lasersnake's Avatar
I thought same thing when got mine, but like posted has to be at operating temp for certain time then blip the gas. Should come on
Old 2/12/12, 03:59 PM
Ditto, mine comes on after the temp is met, time is met and blipping the throttle....
Old 2/12/12, 04:00 PM
A local guy here had to bring his back in because the lopey idle was not installed. He said it was a check box on the software download.
Old 2/12/12, 06:39 PM
yeah i did the following let it warm up for at least 20 minutes and tapped the gas nothing ,then went forward nothing .even drove to the store nothing. i will be calling tomorrow to see if i can drop by to have the tech check it out.
Old 2/14/12, 01:31 PM
FordService's Avatar
Hi heylilcobra,
I hope this was taken care of for you. Let me know if you need me.
Deysha
Old 2/15/12, 08:16 PM
i have another appointment with the dealer saturday.
Old 2/21/12, 05:23 PM
UPDATE
went to the dealership last saturday .i had made appointment on the 13th. go there and guess what the service writer and the tech were off . i guess they could not call to tell me this. so monday i call and make another appointment for this saturday comming up.and btw the skip shift still working when it should not. i really think they did not reflash the pcm.
Old 2/22/12, 09:39 AM
MoscowBoss's Avatar
The web page below has links to both the dealer TK install and customer use instruction docs. Some good information including ways to verify all programing was completed correctly and what may cause issues with things like the lopey idle. Good info for all TK owners.
http://www.trackey.ford.com/trackey/default.asp
scott6809
9/12/15 11:44 PM
5.M0NSTER
9/12/15 08:11 PM
Cdvision
9/5/15 05:22 PM
JTB
Motorsports
9/3/15 10:50 AM
Quick Reply: track key question
