2012-2013 BOSS 302
Track key installed. Traction comtrol question
Old Oct 6, 2012 | 07:26 PM
whiteboss302's Avatar
Ok I got the track key installed and my traction control button does nothing now. I have looked for info on it. Is this supposed to be this way?
Old Oct 6, 2012 | 08:20 PM
Ok so trunk hazard lights and trunk button do any thing. The transmission was replaced at the same time. I think they left something unhooked.
Old Oct 6, 2012 | 09:14 PM
mammothcar1's Avatar
That's exactly what happened.
There is a plug right below the plastic cover that surrounds the shifter, also the same spot were your T/C and hazard switch is located.
The tech should be able to pry this cover up to access the plug.
It's a 3 minute job.
Old Oct 6, 2012 | 09:16 PM
Yea kinda freaked and started searching the forum and Internet before I thought what could of happened through. Thanks you eased my mind
Old Oct 7, 2012 | 03:07 PM
You're welcome.
When the tech pulls the trim up, it will hit the shifter handle but that should still give him enough room to get his hand in there to reattach the plug.
He will not have to remove the handle.
Cdvision
Sep 5, 2015 05:22 PM
BavarianStang
Sep 5, 2015 05:55 AM
JTB
Motorsports
Sep 3, 2015 10:50 AM
Sep 2, 2015 07:33 PM
