Track key installed. Traction comtrol question
There is a plug right below the plastic cover that surrounds the shifter, also the same spot were your T/C and hazard switch is located.
The tech should be able to pry this cover up to access the plug.
It's a 3 minute job.
When the tech pulls the trim up, it will hit the shifter handle but that should still give him enough room to get his hand in there to reattach the plug.
He will not have to remove the handle.
Cdvision
Sep 5, 2015 05:22 PM
BavarianStang
Sep 5, 2015 05:55 AM
Sep 2, 2015 07:33 PM
