2012-2013 BOSS 302
Took the boss to the drag's tonight..
Old May 18, 2012 | 07:00 PM
cobrajetjoe's Avatar
I took the boss to the Shannonville drag strip tonight and had a blast. I did five 1/4 mile passes total. My best pass was 12.98, with trackey on the stock pirelli's. It was my first time on a timed track and there was definitely a bit of a learning curve. Total fun though! Slip below (I was 7)
Old May 18, 2012 | 11:39 PM
batman48195's Avatar
Nice. What do the charge to run your car?
Brian
Old May 19, 2012 | 06:01 AM
wildcobrar's Avatar
Nice MPH and times for running stock tires. What was your launch RPM and your shift RPM?
Joe
Old May 19, 2012 | 06:03 AM
Brian
It was a mix and match night, $25 gets you in and as many runs as you want.
Old May 19, 2012 | 06:26 AM
RoushF150's Avatar
Man and I had my BOSS for 24 hours last night and there was nothing left to polish. I am only an hour and a half drive to the track. I wish I knew I would have run too. My 2011 SHO has run a 13.00 so right around your time. A 12.9 is not bad for a low traction track. I will run MT Drag Radials at the track though.
Old May 19, 2012 | 08:25 AM
Yes, I'm in the process of getting some drag radials...just deciding on sizing etc...lots of info out there..
Old May 19, 2012 | 08:27 AM
Joe
I was launching at 3000rpm with just a small amount of spin. I was trying to shift around 7300 but need some work perfecting that..on my best run I still bounced of the rev limiter in third.
Old May 19, 2012 | 08:36 AM
Five Oh Brian's Avatar
You'll need a 28" tall drag radial to keep you from having to shift into 5th at the dragstrip with your 3.73 gears. M&H Racemasters are very sticky; I run 275/50/17's on my '11 5.0L GT and they hook up perfectly with just a light burnout in the box before staging.
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
Sep 30, 2015 07:02 PM
Cdvision
Sep 5, 2015 05:22 PM
