2012-2013 BOSS 302
Tires - square setup?
Old Jun 7, 2016 | 07:46 PM
mikes70mustang's Avatar
I just read an old thread about how the same size tired as the rear will fit the front. If you have done this, do the tires rub. I'm not getting tires anytime soon. Mine still have the paint on the tires.
Old Jun 7, 2016 | 08:44 PM
redonblackpony's Avatar
With the correct coil overs, negative camber, wheel backspace and offset you can run a 315 upfront on an 11 inch wheel.
Old Jun 8, 2016 | 05:50 AM
Skrapmetal's Avatar
I'm running 285/35/19's on all four corners with stock suspension (for another week or so anyway) with no rubbing.
Old Jun 8, 2016 | 06:31 AM
TripleBlack14's Avatar
Presently I'm running the stock 245/45/19 Pirellis on 9" Boss 302 wheels with a 1" lowering using Eiback Pro springs. No other suspension mods, no effect on camber.
I plan on 275/40/19 square in the near future. I'm assured there'll be no problems. I'm reluctant to go wider since I don't want to replace anything else.
Old Jun 9, 2016 | 04:57 PM
So. Stock wheels and same size rear to front? Like the stock tire size on the front?
Old Jun 9, 2016 | 06:07 PM
Skrapmetal's Avatar
My mistake, I didn't notice the stock wheel bit.
I am not on stock wheels, but my wheels have a more aggressive offset than stock and they still do not rub. I think you'd be just fine.
Old Jun 9, 2016 | 10:26 PM
BaknBlk's Avatar
I've run 19X9.5 with 285/35/19's square for over two years...rear is lowered with Steeda Boss 302 specific springs, front springs are stock....I've never had any problems or rubbing.
Old Jun 10, 2016 | 06:48 PM
I wonder what the point of having smaller fronts was? Especially when there was a complaint of under steer.
cardwiz428
Oct 17, 2024 01:40 PM
wgolden30
Jun 16, 2016 11:16 AM
mkj5013
Jun 12, 2016 09:29 PM
davenport3500@googlemail.
Jun 10, 2016 07:18 PM
michaelkthornton54
May 16, 2016 10:10 PM
