Suspension Question on Laguna Seca
Boss 302:
TIRE AND WHEELS (type, size)
SUSPENSION
Front Independent MacPherson strut with Reverse-L lower control arm, 34.6 mm tubular
stabilizer bar, strut tower brace, adjustable strut damping
Rear 3-link solid axle with limited-slip differential, coil springs,
Panhard bar, 25.0 mm stabilizer bar and adjustable shock damping
Standard 255/40ZR-19 Pirelli PZero, 285/35ZR-19 Pirelli PZero
19 x 9-in., 19 x 9.5-in. wide spoke painted aluminum wheels
Boss 302 Laguna Seca:
SUSPENSION
Rear 3-link solid axle with Torsen limited-slip differential, coil springs,
Panhard bar, 26.0 mm stabilizer bar, body X-brace and adjustable shock damping
Standard 255/40ZR-19 Pirelli Corsa, 285/35ZR-19 Pirelli Corsa
19 x 9-in., 19 x 10-in. machined lightweight aluminum wheels
If they are not at least poly, I will need to redo the suspension.......If the curb weight was in the Z06 range, then maybe not. The difference on my GT500 between an adj UCA and the torque arm were night and day. With the stock LCAs and rubber bushings you got terrible wheel hop. The diff just is squirrely under the rear of the car with all that play. Now the Boss won't have near the torque and it may not be as big an issue. The photos I saw of the underside looked to have similar "flimsy" LCAs to the GT500....although they looked shorter? Well anyway, here's to hoping Ford actually put a race quality suspension on the LS.
Humm first off the 2011 brembos GT dose not under steer . They change the lenght on UCA on the 2011 mustang it now longer . Here a video from MT iam sure most of you have all seen it already but i post it for the people that mite not seen it yet. If you watch this all the way through you see when he talks about the 2011 GT with the brembos he says one of the best thing about the car was it did not under steer.
http://www.youtube.com/watch?v=cp7OUWm4BFI
So that were ford started at when they when to make the Boss so iam thinking in stock form it should been good . If you look at what ford did to the Boss they work on all the bad points that were in this video about the GT
****, I need to get myself back behind the wheel and onto the track again. It's going to be a loooong wait until Spring.
I thank all of you for the input. I thought occured to me that maybe the Boss LS could have similar suspension settings to that of the Shelbly gt 500 KR????? Is this at all possible?
The Boss suspension will act to limit dive somewhat, the front end is already lowered by 11mm. The stiffer Boss springs will limit the travel under steady state loads, while the increased damping will slow down the rate at which the car dives. Roll stiffness is increased both by the springs, and by the stiffer rear bar, though I doubt the rear bar will visibly change the amount of roll. It will make the front end bite better than the stock GT. Again the increased damping will slow down the transition into roll, so it won't be as pronounced during the corner entry phase.
Evil_Capri
Sep 11, 2015 08:39 AM
