2012-2013 BOSS 302
A Summary of BOSS Changes
Old Aug 15, 2010 | 07:03 PM
ferrarimanf355's Avatar
Cloth/suede...
Fine by me, then. Leather is real sticky in the sauna that's Florida summer weather.
Old Aug 15, 2010 | 10:30 PM
PTRocks's Avatar
Found one more! - The GT500 SVTPP finned aluminum diff cover. you have to look very carefully to see it here.
There is another underside shot looking forward from the back of the car, but I haven't found it yet.
EDIT: I've found one on FireDragon's SVTPP GT500, see my post below.
Old Aug 16, 2010 | 05:52 AM
What's a finned aluminum diff cover, and how is it different from the diff cover in the vanilla GT?
Old Aug 16, 2010 | 07:29 AM
PTRocks's Avatar
Here's a shot of FireDragon's SVTPP GT500:
It's a performance diff cover that performs the following functions to make the diff last longer under performance/racing conditions:
- allows for a higher oil capacity for better lubrication
- fins for dumping more heat
- Increased stiffness to better support the diff and bearings for longer life
Old Aug 16, 2010 | 07:42 AM
Originally Posted by PTRocks
Here's a shot of FiredDragon's SVTPP GT500:
One less upgrade to purchase, then. Thanks.
Old Aug 16, 2010 | 08:52 AM
Dr Evil's Avatar
hmmm, it doesn't look like I can edit now. Maybe moving the thread does this?
Old Aug 16, 2010 | 09:12 AM
PTRocks's Avatar
you can't edit posts after a certain amount of time. corvettedreamin dealt with it in his build/Delivered/VIN thread by copying and pasting his list into new posts.
Old Aug 16, 2010 | 12:38 PM
Dr Evil's Avatar
2012 Boss Mustang Upgrades
Powertrain
Boss 302R Intake
Forged Pistons
Forged Con-Rods
Race-Spec Main and Rod Bearings
Sodium Filled Exhaust Valves
Hi-Lift Cams
7500 RPM Limit
CNC’d Heads
Oil Cooler
Larger Radiator
Revised Radiator Plumbing
Revised Oil Pan Baffling
Race Inspired Clutch
3.73 Axle Ratio
Finned Aluminum Diff Cover
Limited Slip Diff with carbon fiber plates (Torsen Limited Slip Available)
Quad Exhaust
Suspension
Higher Rate Springs (lowered 11MM front – 1MM rear)
Adjustable Struts/Shocks
Tuned Electronic Steering with 3 Settings
Unique traction control system settings
Unique electronic stability control settings
Body
Black or White Roof Panel and Coordinated C-Stripe
Unique Front Facia with Blocked off Fog Lamps and Splitter
Small Rear Spoiler
Interior
Alcantara Steering Wheel
Unique Shift ****
Unique Cloth Seats (Recaros available)
Dark Metallic Instrument Panel Finish
Unique Guages
Unique Door Sill
11 Pounds of Sound Deadening Removed
Brakes, Wheels and Tires
Brembo 14 inch vented discs front
Boss specific rear compounds pads rear
Vented Brake Shields
Unique ABS tuning
Reinforced Brake Lines
Lightweight 19X9 and 19X9.5 Wheels
Pirelli P-Zero Tires 255/40/ZR19 Front 285/35/ZR19 Rear
Laguna Seca Package
Available in Black or Silver with Red Accents
Rear Seat Delete
Standard Recaro Seats
Rear Body Stiffening X-Brace
Softer Front and Firmer Rear Springs
Stiffer Damper Settings
Larger Rear Anti-Roll Bar
Unique 19x9 Front and 19x10 Rear wheels
Pirelli Corsa Tires 255/40/ZR19 Front and 285/35/ZR19 Rear
Larger Front Splitter
Pedestal Rear Spoiler
Brake Ducts
Torsen Diff Standard
Auxiliary Gauge Package with Oil/Water Temp and Lap Timer
Unique Laguna Seca Fake Gas tank thing (lol, forgot what they call it)
Old Aug 16, 2010 | 01:06 PM
Boomer's Avatar
I edited the original for ya
Old Aug 16, 2010 | 01:22 PM
Mus408's Avatar
Surprised Ford didn't include a "Boss 302" race helmet. You would need it to enjoy the car on a track!
Old Aug 16, 2010 | 11:36 PM
Ice Hawk's Avatar
Dude! That would be awesome. I know helmet manufacturers made special replica helmets for SE models of motorcycles. I have a 2006 Yamaha R-6 Anny Ed and the matching SE Helmet from Arai. Wonderful idea.
If nothing else, I could always get one custom painted.
Old Aug 18, 2010 | 07:55 AM
PTRocks's Avatar
I don't know if you would call it a change, but it appears that the BOSS 302 uses the V6 Perf Pack strut tower brace.
Old Aug 18, 2010 | 10:38 AM
xlover's Avatar
actually its the same one the 2010 GTs used, probably becuase the need to clear that big intake on the boss. They can use the new fancy one on the 2011 GTs because the intake is lower than the 2010 GTs.
Old Aug 20, 2010 | 02:16 PM
rick0202's Avatar
Is this true "11 Pounds of Sound Deadening Removed" for the Boss and not the LS? Pretty much makes it a track only car. Funny how other threads are talking about an electronics package and shaker 1000. Now how is Ford going to recoup all the money they put into this engine? I don't think 3020 units will pay for that. Use it in the Mach 1?
Old Aug 20, 2010 | 02:20 PM
rick0202's Avatar
Is this true "11 Pounds of Sound Deadening Removed" for the Boss and not the LS? Pretty much makes it a track only car. Funny how other threads are talking about electronics package and shaker sound systems for the options. Now how is Ford going to recoup all that engine development money? I don't think 3020 units will pay for that. Maybe this is the Mach 1 engine also?
Old Aug 20, 2010 | 02:26 PM
JonW's Avatar
I heard $39K for the Boss and my source said that figure is reliable. And if you think about it, that's probably about right. Most of the Boss goodies are substitutions for parts that are already on the car (engine, wheels, tires, shocks), so it's not like you're paying for them twice like you do when you buy aftermarket parts. Plus, figure in the deleted pieces (fog lamps, sound deadening, etc) and I think $39K is very realistic. Remember, Ford has a lot of R&D money tied up in this car, and the only way they can get it back is to sell them.
Since the Boss is based on the base GT, I doubt it will have any different options than the base GT has and maybe even less. Which is as it should be. If you want gadgets, buy a GT Premium or a GT500.
Old Aug 20, 2010 | 04:07 PM
PTRocks's Avatar
there will be more than 3020 units. Ford will build as many as people want, likely for the 2012 and 2013 model years.
Old Aug 20, 2010 | 04:35 PM
Whammer's Avatar
As Seinfeld said during the opening clip on his tv show- "Limited? Yea, limited to how many they can sell."
Old Aug 20, 2010 | 04:40 PM
hori's Avatar
anyone know if hids will be an option?
Old Aug 20, 2010 | 04:42 PM
  #40
JonW's Avatar
If it's not an option on the base GT, it probably won't be an option on the Boss. Check out the base GT equipment at www.fordvehicles.com
