2012-2013 BOSS 302
Stock OEM shifter HANDLE?
Old May 21, 2012 | 09:41 AM
JPC's Avatar
JPC
A question to all those who have taken out your stock shifters AND others that seen the shifter handle up close:
Can I REMOVE the stock shifter handle ONLY?
...and replace it with a hurst/steeda/other HANDLE?
Old May 21, 2012 | 11:11 AM
boss man's Avatar
As long as the thread on the shifter handle is the same.
Old May 21, 2012 | 02:00 PM
c6dreamvette's Avatar
Yes,
Use a heat gun and wrap your boot in aluminum foil so it does not damage the leather. after about 5-10 minutes of heat use a stap type oil wrench (either rubber or a nylon material) to loosen the ****.
Old May 22, 2012 | 10:54 AM
JPC's Avatar
JPC
let me expand,
I want to change JUST the handle and KEEP OEM shifter mechanism
#5387201
HURST #538-7201 CHROME PLATED STEEL SHIFTER STICK
Hurst 5387201 / 2387201 Replacement Shifter Stick
Photo is Representation, Specs Image is correct
6-3/8" Long
Chrome Plated Steel
Hurst “bolt-on” shifter sticks are ideal for use in custom applications where a particular height or offset is required. These shifter sticks are constructed from high strength steel and are stamped with the Hurst name. All sticks incorporate a 3/8-16 thread size for use with many popular Hurst T-handles and shifter *****. Bolthole size is 3/8” I.D. with 7/8” center-to-center spacing.
Old May 23, 2012 | 05:57 AM
ace72ace's Avatar
I can understand wanting a cool look and better feel than the stock shifter. But if you are going through all that trouble you may want to consider at least an upgraded Barton shifter bracket, or shifters like Steeda, or if you want to go all in, an MGW... I have an MGW on order for my '13 Boss.
When I was shopping around, I looked at the MGW videos and was surprised how junky and cheap the stock unit looks.
http://www.mgwltd.com/2011-short_thr...l_videos.shtml
Old May 23, 2012 | 07:35 AM
gashi25's Avatar
I have the hurst and absolutely love it! I deff recommend doing the entire swap instead of just the handle. When I get home tmrw, I can take pictures of the stock shifter I still have it.
Old May 23, 2012 | 07:38 AM
JPC's Avatar
JPC
thanks you very much!!!!!
Old May 25, 2012 | 08:47 PM
gashi25's Avatar
Here are pics from stock 2010 shifter also I def suggest purchases the entire unit
Attached Thumbnails Stock OEM shifter HANDLE?-image-1552269938.jpg   Stock OEM shifter HANDLE?-image-673358537.jpg   Stock OEM shifter HANDLE?-image-799364553.jpg
lowblustang00
Sep 5, 2015 12:18 PM
SilverBullet13
Aug 13, 2015 09:11 AM
tdf017
Aug 5, 2015 10:13 AM
