2012-2013 BOSS 302
Steeda Boss 302 Handling Pak - worth it?
Old Dec 6, 2011 | 01:31 PM
ace72ace's Avatar
Question Steeda Boss 302 Handling Pak - worth it?
http://www.steeda.com/store/boss-302...k-stage-1.html
Old Dec 6, 2011 | 02:46 PM
SteedaGus's Avatar
YES
If you are into handling, which most Boss owners are.
This package will noticeably improve grip, steering response, and reduce body roll. It will also give you camber adjustment that is not available from the factory.
Old Dec 6, 2011 | 03:07 PM
ShaneM's Avatar
Originally Posted by SteedaGus
YES
stage 1 implies more, so what's next?
Old Dec 6, 2011 | 03:21 PM
06GT's Avatar
Stage 2, obviously
SteedaGus's Avatar
Nice... LOL
The Stage 2 kit is those same components plus front and rear swaybars, both adjustable. Front bar at max adjustment has 27% more roll stiffness, the rear bar has 83% more roll stiffness at its stiffest setting, both are adjustable to dial in handling balance.
http://www.steeda.com/store/stage-2-...dling-pak.html
Please excuse the formatting errors on that page, I just noticed them. My web guy will have to fix that tomorrow.
Old Dec 6, 2011 | 03:24 PM
06GT's Avatar
Just to be clear--you're talking about stiffness difference vs. the GT bars, right?
Old Dec 6, 2011 | 03:31 PM
SteedaGus's Avatar
No, Boss. Boss has a 34.6MM front bar, and a 25mm (1 inch) rear bar.
From the data we have from Ford, the Boss bar although slightly thicker than the GT has a different wall thickness and is approximately the same roll stiffness as the GT bar.
All our numbers are based on that information.
Old Dec 6, 2011 | 06:21 PM
5 DOT 0's Avatar
What's the max neg camber you can obtain with your strut mounts?
Old Dec 6, 2011 | 08:19 PM
Krnnerdboy's Avatar
I'm most likely going to go with this package. A little more body control and rear end stability will go a long way on the track for me....
can you guys humor a newb for a second? So I understand that if I was to add a higher spring rate it would cause that end to break traction sooner? EG: If I'm understeering I'd add more spring rate/larger roll bar to the rear, right? so how does having a higher spring rate increase handling? Does it only increase feel and lose more grip? What is it that I'm missing here?
Old Dec 7, 2011 | 12:12 AM
Zoldier's Avatar
The included adjustable strut mounts feature a +1/-1 degree range of camber adjustment.
Old Dec 7, 2011 | 06:08 AM
adam81's Avatar
Gus.....is there any data like lap times or whatever that proves either stage is better than stock? This is not an attack on the product what so ever. I am just curious. I am waiting for someone to come out with staged kits like this that is PROVEN to be faster around a track. I think I asked this of you before but can't remember for sure...
Old Dec 7, 2011 | 07:50 AM
Mike.B's Avatar
Thanks for the help today, Gus. Install is scheduled for tomorrow.
Old Dec 7, 2011 | 08:18 AM
5 DOT 0's Avatar
If that's true it's not enough. You need -2+ for tracking your Boss.
Old Dec 7, 2011 | 08:49 AM
SteedaGus's Avatar
No problem, I think you did ask this before and I had round about numbers for just the springs. Testing was done by different drivers at different tracks and all saw between 1 and 3 second improvement in lap times.
I can't provide numbers for the panhard bar specifically, we chose it because it has already been proven as a benefit in professional racing. For years this part has been approved by Grand AM and Koni Challenge series and used in practically every FR500 out there racing in these series because of its handling benefit and adjustment for vehicle setup.
Having camber adjustment for racing has its own benefits including being able to change your setup for different tracks or simply for street vs track use.
Old Dec 7, 2011 | 08:50 AM
SteedaGus's Avatar
If you are hardcore about it, yes. Not for everyone.
Old Dec 7, 2011 | 09:26 AM
adam81's Avatar
Thanks Gus. Is the 1-3 seconds just for the springs?
Old Dec 7, 2011 | 09:41 AM
Zoldier's Avatar
I was thinking the same thing.
Old Dec 7, 2011 | 11:43 AM
2012YellowBoss's Avatar
I am not an expert on this but so far the -1.8 has been working well with my NT-05's. It may have something to do with tires that are run not just driving style Been asking for a lot of advise at the tracks but since I got the pressures correct (or better) they have not worn into the arrows on the sides of the tires. I wanted to change the setting to -2 or more but everyone tells me to leave the camber setting alone (knowledgeable people). This is of course with stock springs.
Old Dec 7, 2011 | 12:24 PM
06GT's Avatar
Get tire temps ASAP with an IR pyrometer when you come off track. You will see then if you need more camber. Ideally, you want Inner, Middle, and Outer readings all within a 10*F range.
But for reference, the Grand-Am teams are running in the -3 range.
Old Dec 7, 2011 | 12:37 PM
LOL, it just arrived in the mail yesterday. Too late for Daytona but I have been practicing taking the temperature of my dog from across the room
Ran the pressure about 8 pounds higher at Daytona and did not wear the tires one little bit.
