Someone's Boss...with a Kenne Bell and 18psi!! Could it be mine??
Man that is awesome!
A lot of these hard core track guy's will give you crap but just my 2 cents..............You have a bad a$$ car.
Also, Why would the rear blow? Is it not suppose to be bullet proof? If not then I wasted 2 grand on it![Stickpoke](https://themustangsource.com/forums/images/smilies/stickpoke.gif)
Go dominate the 1/4 mile now
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
You could build a civic to beat it for less, but who cares. These arguments are just a pissing contest.
Just out of curiosity, does anyone know- would making the camber -2.5* counter act the additional weight of the difference between the s/c #'s and the factory components #'s? I'm trying to picture the impact of the weight addition. Heck I'm 235 lbs and a smaller guy or gal could potentially save 130 lbs or so just person to person...
Good luck with the SC! This thing is going to be a monster.
heres some help for the rear end when you blow it up.
have been following it.
http://www.s197forum.com/forum/showthread.php?t=66420
beers
beers
Originally Posted by 5 DOT 0
Big Vito you need a big a$$ super charger on your LS, it will help you drive Flat Out.
I'm glad you agree with me.![Wink](https://themustangsource.com/forums/images/smilies/wink.gif)
I won't be doing that to mine,
beers
beers
![Worship](https://themustangsource.com/forums/images/smilies/worship.gif)
WOOOOOOoooooOOOOO
I have a wavetrac in my 9" Rear. Quiet and awesome. Been in for 2 weeks.
You sure they make it for a 31 spline axle. I see 8.8 on their website, but 33 spline axle, non c lips only. Also the 8.8 is the most expensive too
http://www.wavetrac.net/application.htm
9-inch 31 Spline axle (export only): 56.309.175WK $995.00
9-inch 35 Spline axle (export only): 56.309.178WK $995.00
9-inch 35 Spline axle Available exclusively in the USA and Canada from Moser Engineering
9-inch 31 Spline axle Available exclusively in the USA and Canada from Moser Engineering
Taurus SHO V6 5-speed (exclusive) 56.309.170WK contact SHO Nut Perf
8.8 inch RS 33-Spline (non c-clip) NEW! 56.309.183WK $1,095.00
not on the site yet but have one to fit the boss/gt.
beers
#40
The beauty of a GT500 is in the stuff you dont have to worry about like grenading the clutch, MT82 or Torsen and having a cooling system that can handle 700+ hp in blistering heat and so on.
The roadrunner can make serious power for sure and Ford may have even envisioned people making stupid power on the motor (like your 800+ at the crank) but one thing is for sure, the rest of your car was screwed together with 444hp in mind.
