So here's what we need to know...
Let's compile a list of burning questions surrounding our soon-to-arrive Bosses. You know, the stuff we just HAVE to know. I'll lead off
1. What's the deal with the side exhaust restrictor plates? How loud removed?
2. Are the shocks just 5-step adjustable, or do they have infinite adjustment levels?
3. Need Dyno charts - normal and with Track key, also with and without restrictor plates in the exhaust.
4. Track times, of course, as you can get them, to compare with the "pro" results we've seen.
5. I am also interested in knowing what HASN'T been discussed yet. What pisses you off about the car, if anything?
I realize it may take some time to get answers. If all of these haven't been answered by the time I get mine, I shall be happy to address all of this, and more.
So...anyone else got a "bug"?
I stopped by the dyno shop yesterday and I was planning on doing just what you asked next week. One big problem with that. TracKey has no ETA!!
IF I get my car Saturday you'll hear what it sounds like with no discs.
My only questions so far:
Does intallation of the cooling ducts require cutting into the front bumper?
How much headroom do I have in the Recaros with my helmet on?
Will it hit the cement lip on my garage when I enter?
Add to your list the PCM lockdown requiring driving it a few miles before unlocking it. Sounds like STIguy had to drive about 4 miles. On the GT500s it was 5 consecutive miles or 50 starts to unlock the supercharger.
What is the maximum wheel offset allowed front and rear?
What is the factory wheel offset, both reg Boss and LS?
What are the scale corner weights including f/r and cross?
How much do the Recaro's weigh?
What is the static measured camber curve at factory ride height?
How much caster from the factory?
What is the best supplier for a clear bra, fender qtrs, etc?
What fluid is in the trans from the factory?
What is the weight of the OEM rotors f/r (incl unsprung wt.)?
What is the maximum redline?
How to set launch control?
For starters....
Dave
For starters....
Dave
I've requested delivery for next Thursday. It's in Brentwood, Ca, not too far from you. It all depends on if it can be offloaded and trucked to the dealer by Wednesday. My dealer is great, he's going to call the rail yard and see if they'll expedite my car.
I believe that once you get hooked up to a UP Autorack train, it makes very few stops. Interesting factoid, the average speed of US freight trains is only 20-30 mph. This is because of frequent stops and pullovers for higher priority traffic. The Autorack to the west coast must be a higher priority than regular freight.
Originally Posted by 4pipes
I'm 6'2", I hope I'm ok. I've had problems in other cars.
Mine is here so I can help!!!
Not loud in the car...just deep, and the slight backfiring and popping under decel is nice-I have yet to have anyone drive the car besides me so I cannot comment on the outside noise
2. Are the shocks just 5-step adjustable, or do they have infinite adjustment levels? 5 step adjustable set on 2 from the factory
3. Need Dyno charts - normal and with Track key, also with and without restrictor plates in the exhaust. I can't help with this ...yet!
4. Track times, of course, as you can get them, to compare with the "pro" results we've seen. Same as above!
5. I am also interested in knowing what HASN'T been discussed yet. What pisses you off about the car, if anything? No telescoping steering wheel...and ride height...looks like an offroader
