Notices
2012-2013 BOSS 302
Shifter knob
Old 8/24/11, 05:31 PM
  #41
11SHELBYGT500's Avatar
Originally Posted by HPOA
I received my KB Boss on Friday and my custom shift **** from grabberpony happened to arrive on Saturday. The problem is that I have been unable to remove the factory shift ****. I have been turning it counterclockwise, but the thing will not budge. I have even resorted to using clamps and other tools. I am wondering if anyone else has had this problem, or if it is possible that they have started gluing the ***** on. Thanks in advance.
You need to get a heat gun and a strap wrench. Wrap aluminum foil around your dust boot to protect it from the heat gun. Heat up the base of the **** and use the strap wrench to loosen. They use loctite on the ***** and are a !!!!! To get off.
Old 8/24/11, 05:40 PM
  #42
06GT's Avatar
That's not where reverse is...
Old 8/24/11, 06:41 PM
  #43
bigbossman's Avatar
Originally Posted by Fat Boss
I've seen some rednecks out west who use most of the deer they shoot. This includes the ******* for a shift **** cover... Put it on when it's "wet" and it'll shrink and dry to a nice wrap.
They's rednecks where I come from that'll epoxy a hog's teste and shine it bright as day and shift that thing til resin comes out--then it really grips. I'm thinking about swappin that ****...then I could be bosshawg. Hog killin time ain't but three months off.
Old 8/24/11, 08:51 PM
  #44
5 DOT 0's Avatar
Is Grabber Pony going out of business? I noticed they have no shift ***** in stock and most other items are out of stock too.
Old 8/25/11, 12:55 AM
  #45
HPOA's Avatar
Thanks that worked perfectly. It was still a pain, but I was able to finally get it off. The new shift **** looks great.
I was also wondering if Grabberpony is going under because Mark took a long time (almost a month) to return my phone call, and now it says all of their ***** and adapters are out of stock.
Old 11/16/11, 12:00 PM
  #46
05mealready's Avatar
Can you post a pic of the new set-up?
jim010
6/24/24 04:23 PM
7/8/16 08:53 AM
K.A.I.N
9/25/15 03:27 PM
dbrinkley2008
9/9/15 07:02 AM
Quick Reply: Shifter knob
