2012-2013 BOSS 302
POST TRACK TIME WHEEL SHAKE
Old Sep 28, 2011 | 12:58 PM
cloud9's Avatar
Originally Posted by StillIntense
Dang Gary, your problem is that you're driving too hard. Take it easy, enjoy life, slowdown! If I remember correctly that's a bit more camber than the Boss 302R teams dial in.
We landed at -2.7 so we'll see what happens. As bad as my R6s looked last Sunday, -5.0 might not be enough
Old Sep 28, 2011 | 09:11 PM
2012B2LS's Avatar
Originally Posted by cloud9
I am at -2.2 and after prematurely cording the outside edges of my Hoosiers at MPH this weekend it's going into the shop tomorrow for -2.5.
Did your R6s take anywhere close to the beating my left front took? And I retired early to catch my flight.
Old Sep 29, 2011 | 05:12 AM
cloud9's Avatar
Double post......
Old Sep 29, 2011 | 05:13 AM
cloud9's Avatar
I didn't get a look at yours but your Dad said it corded. I should have taken a pic of mine. It was beyond ridiculous how misshapen the outside edges of both my fronts looked. I had even swapped them side to side between the 4 sessions I ran them at BIR two weeks prior so ended up cording both the fronts, although the left was worse. The rears have 9 heat cycles and only look about 1/2 used up at most. I am hoping the add'l camber helps the new fronts live long enough to flip them on the rim after next weekend.
Old Sep 29, 2011 | 11:49 AM
2012B2LS's Avatar
Let's just say that it looked like I had two bright polished wheel lips on either side of the tire rubber because of all the steel showing through the edge of tire when I pulled in for the last pit. I could hear it singing to me on the last lap.
Old Sep 29, 2011 | 12:55 PM
cloud9's Avatar
Well now I know I can push them further next time
Old Sep 29, 2011 | 01:12 PM
StillIntense's Avatar
I'm going back to have my wheels/tires checked out this afternoon. More to follow Friday.
Old Sep 30, 2011 | 05:53 AM
OK, both tires failed the road force test miserably (51 lbs and 42 lbs). Rotated the tires on the rim to try and make it better, no help. Essentially both tires are done, and the dealership is looking into getting them covered under warranty. No track time on these tires, always ran the recommended tire pressure, and only 1500 miles. We'll see what happens next.
Old Oct 1, 2011 | 08:25 PM
jouster's Avatar
Originally Posted by itrack
I also have this issue and thought it was the tires. Just got them balanced today and have the same problem. I have a slight shimmy in the wheel that goes away under braking. Let me know what they find out.
Gotta be the rotor if the shimmy corrects under breaking.
Heat Sink? Possibly rotor got too hot and warped slightly?
But Let us know when you confirm the problem, so we can all venefit from your experience.
Cheers,
Jouster
Old Oct 3, 2011 | 06:46 AM
As I said, it does NOT shake under braking. It's not the rotors, and we confirmed that the tires are bad.
Old Oct 3, 2011 | 06:47 AM
Sorry, wrong guy responding......
Godspeed302
Oct 28, 2015 01:22 PM
tukatz
Aug 13, 2015 09:27 AM
07 Boss
Aug 8, 2015 11:04 AM
Bert
Jul 25, 2015 02:13 PM
dmichaels
Jul 18, 2015 08:32 AM
