2012-2013 BOSS 302
Ok...REALLY stupid question....
Old Oct 10, 2011 | 04:12 PM
ulev1st's Avatar
First off..I am at work and DON'T have my manual to look this up on my own..so be kind.
The car was REALLY nasty from last weeks Track Day so I dropped it off at the detail shop today..I figured it was already nasty, a little more rubber wasn't gonna hurt, so I TRIED doing some donuts in an empty parking lot. I had Traction Control OFF and it went around once with no problem but then it stumbles and shut down on power. There was a MOMENTARY flash of a yellow dash warning light that I caught out of the corner of my eye but it went out as soon as I got out of it. I tried again with Advance Track on..same results....any ideas?
Old Oct 10, 2011 | 04:52 PM
11SHELBYGT500's Avatar
Are you sure you had it completely off? You applied the brake and held the traction button down for 5 seconds?
Old Oct 10, 2011 | 04:57 PM
adam81's Avatar
Yep. Even with traction control off or with Advance trak on the system will still kick in. It is the stability control. Traction control only accounts for the tires spinning when you are going straight. Stability control is when turning, and the rear starts sliding. You have to shut everything off. You do this by doing the following:
1. Peg the brake to the floor
2. Hold the traction control button down for 5 seconds (maybe a bit longer)
3. I believe it says Advance Trak off (someone please clarify this)
All the nannies are disabled.... Nothing will kick in to stop your fun
Old Oct 10, 2011 | 05:11 PM
ulev1st's Avatar
Ok THANKS..I did NOT do that! I appreciate the info.
Old Oct 11, 2011 | 03:52 PM
dean_acheson's Avatar
Yes, there are three different settings.
1. hit the button once - disables traction control - leaves on stability control
2. Press the brake (no throttle) and press the button twice- sport mode - puts steering in sport/partially diables traction and stability control.
3. Press and hold button for 5 + seconds and hold brake petal at a standing stop - shuts down everything (the dash will say that your stability control (not traction) is off.
Ecostang
Nov 3, 2022 08:50 PM
kponypower
Jun 17, 2020 07:17 AM
K.A.I.N
13
Dec 26, 2015 01:29 PM
seaclam
Sep 25, 2015 01:29 PM
wannabe
Sep 23, 2015 05:36 AM
