New Wing
New Wing
Installed the new spolier yesterday, still have a lot of paint issues to work out. Thinking of doing all flat on top and leaving the side the way it is. One real set back with this spoiler, it had screws not studs mounted in the spoiler. That made it very hard to attach, then one fell into the trunk which caused all kind of problems, any way something to think about if you order one.
Looks great Scott. Is that also the CS a.k.a. LS spoiler without the red accents? I saw one on a black CS at the dealer this weekend and it looks like yours. I love how the YB looks gold in that last pic.
The wing is the CS/LS style yes but after market. I still need to work on it and will have to go get some studs for it, it was a pain to mount.
Originally Posted by LQQK
I finally got to see and sit in a Boss today. At the NY auto show. After my wife wiped my drooling chin, I sat in it and fell in love all over again!! Love the recaro's. I think I'll change the spoiler too. Can't wait. I think it's even worse now that I sat in it!!
Looks good Scott. Can you explain what you mean by screws not studs? My impression was you screw eight bolts into the four spoiler pedestals from inside the trunk lid. So when you say studs I'm not sure what you mean. Also did you drill four additional holes in the trunk lid for the spoiler? You're using the stock trunk lid right?
I ended up dropping some screws into the space between the deck lid top and inner bracing. This led to all kinds of problems, I tried to fish it out with a magnet but that got stuck. At that point I removed the deck lid and shook them out but one stuck to the magnet. I was going to leave it for now but then I saw a bulge in the trunk from where the magnet was stuck.
At that point I needed to cut a big hole in the inner bracing to get it out. I cut that it in a spot under the cover and pulled it out but the bolt fell off the magnet and inside again. There was a slight bulge in the lid and I pressed down on it with my fingers, unfortunately it mush have been right where the lost bolt was and I made it worse.
Really sucks but I plan to paint the lid black so they will just need to fix that first.
Anyway yes the four rear holes do line up minus the 1/8 inch I had to deal with because the spoiler was not correct. You need to drill out the four forward holes.
Scott,
Question on your louvers. In the first picture, it seems like the louvers end about an inch or two before the backlight's glass line along the trunk, while in the other three, they appear to go down to the bottom of the backlight's glass line. It this an optical illusion or do they really leave that much space at the bottom of the backlight?
Mike, don't forget the prop rod if you do this
Oh wait you don't need it for the 69 Here are some shots from inside. The four upper holes are from the original spolier, you need to make four more below them. You can see the hole I had to open circled in black, did not come out well. The other shots show them with the caps in place, as I said I did just the two inner holes.
The pic with just the circle would show where to drill and cut the two outside holes.
The last pic shows the big hole I had to open on the bottom left to remove the magnet.
Scott,
Rick - I wound up ordering the GT500 wing from Ford. I didn't specify but managed to get the GT500 track pack wing with the Gurney Flap which is a bonus given it's road racing roots. I decided to go Kona Blue, haven't gotten it back from the painter yet but dying to see how it looks on the car.
