2012-2013 BOSS 302
It just dawned on me...downside of no disks!
Old Mar 28, 2011 | 10:25 PM
4pipes's Avatar
I might not be able to pass the 90db limit at Laguna Seca under full throttle! I'm either going to have to put them back in or buy the dump valve. Definitely not going to drill them out now.
Old Mar 28, 2011 | 10:29 PM
tonylop33's Avatar
Given that the sound meter is on the right between t5 & t6, maybe just install the right side one for that track?
Old Mar 28, 2011 | 10:46 PM
4pipes's Avatar
I wouldn't want to take a chance on getting black balled, and I hate having to lift there.
Old Mar 29, 2011 | 09:03 AM
Mus408's Avatar
Geez...It's a race track. Has this what the USA has come too??
Old Mar 29, 2011 | 09:49 AM
fuhrius's Avatar
depends on who you run with
the limit is 92db. depending on temp and wind direction, I've seen lots of cars squeak by that were way over 92db. and, depending on who you're running with, you usually get two cautions before you get pulled from the track for noise. granted, a caution means that your session is over...so getting cautioned really stinks. and the sound booth is track right...hence all the funny contraptions you see some folks running that angle their exhausts to the left.
it's one of the only, probably the only, downside of laguna. it's what happens when lots of rich homeowners get together and pass a city sound ordinance. LS is only allowed 4 days a year when there is no sound restriction. 92's actually not too bad. the only stock cars I've seen not pass there are 997 gt3's and the occasional ferrari. the gt3 guys use these little $3 plugs to plug the vacuum lines that keep their secondary exhaust openings from actuating...resulting a little loss of power. but I've never seen anyone not pass if they simply lift out of 5. but I hear you...I hate to have to lift there.
Dave, when are you going to LS?
Old Mar 29, 2011 | 09:54 AM
4pipes's Avatar
Laguna Seca used to be a secluded race track on Fort Ord Government property. Over the past 45 years there have been many changes in the area. Fort Ord closed, large houses have popped up everywhere. Now, they are restricted to an annual average noise level.
Most track activities are restricted to 90dB so that major events like ALMS, FIM Gran Prix, etc., run unrestricted.
90 dB can be difficult to achieve especially on some days when the atmosphere is not cooperating.
Old Mar 29, 2011 | 11:11 AM
StillIntense's Avatar
Dave, I would be a bit surprised if you had a problem. I've run on MANY tracks with a 90dB limit with my 95R, and it was louder than you could believe! No cats, and essentially no mufflers. Never had a problem and that car was louder than a lot of purpose built race cars.
Old Mar 29, 2011 | 11:34 AM
4pipes's Avatar
I had a Ferrari with Tubi exhaust and used to get busted there. Had to lift going up hill into #6.
Old Mar 29, 2011 | 11:47 AM
MJockey's Avatar
Welcome to CA, the land of restrictions.
Does anybody know if they had the disks in for the boss media event?
Old Mar 29, 2011 | 12:31 PM
4pipes's Avatar
I believe they did not.
Old Mar 29, 2011 | 12:38 PM
Exactly.
Old Mar 29, 2011 | 12:41 PM
MJockey's Avatar
So it shouldn't be an issue then. I would still bring them with you just in case.
Old Mar 29, 2011 | 01:11 PM
5 DOT 0's Avatar
All of the cars run on the track at the Boss event in February had no restirctor plates.
1001yos
Sep 8, 2015 10:05 PM
nismos13s14
1994-2004 V-8
Jul 31, 2015 12:55 PM
jbuch
Mar 11, 2005 07:43 AM
z71mudder199
Feb 11, 2005 03:36 PM
