2012-2013 BOSS 302
I totally blame cloud9
Old Mar 23, 2011 | 09:20 AM
1FAFP90's Avatar
I've been calling every 8 hours to track my railcar. Wake up, call. Midday, call. Going to sleep, call.
Thanks, cloud9
To pass the time I calculate avg MPH between locations.
Sometimes it sits
Other times it chugs along
After 3 days of movement, it's halfway here
Old Mar 23, 2011 | 10:11 AM
4pipes's Avatar
My train averaged 30mph from Chicago to California.
Old Mar 23, 2011 | 01:12 PM
5 DOT 0's Avatar
Did you get your hands on it yet?
Old Mar 23, 2011 | 01:18 PM
4pipes's Avatar
Any day now....Saturday at the latest. Already ordered new helmet, fire extinguisher and mount, tranny scoop, and brake ducts. I'm a little concerned about what's required to install the ducts.
Old Mar 23, 2011 | 01:27 PM
StillIntense's Avatar
Dave, I have the brake duct kit. The written instructions are clear, but the pics that come with it are really dark and useless. Looks to me like we remove the lower front fascia to get at the cutouts. We need a 2 3/4 inch hole saw to cut out the panel on each side. Other than that, looks pretty straightforward.
Old Mar 23, 2011 | 01:30 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
Thanks, cloud9
Sometimes it sits
I think you might have a little problem there. OCD can be very destructive to a person's life.
Old Mar 23, 2011 | 01:31 PM
4pipes's Avatar
Do we have to remove tires and/or rotors to install new backing plate? I have a 4 post lift and was hoping to install them without jacking the car up while on the lift.
Old Mar 23, 2011 | 01:34 PM
Yes, that's what the instructions call for. Including removing the rotors from what I recall.
I have a lift as well but plan on simply putting the front end on jackstands.
Old Mar 23, 2011 | 01:52 PM
4pipes's Avatar
Maybe we can talk by phone when we get closer, I haven't received my kit yet.
Old Mar 23, 2011 | 02:03 PM
Dave, sent you a PM with phone #.
Mark (StillIntense)
Old Mar 23, 2011 | 02:18 PM
06GT's Avatar
If you have a thin, ratcheting 10mm box-end wrench, you can get the backing plates off without removing the rotor.
Old Mar 23, 2011 | 02:29 PM
4pipes's Avatar
We should probably start a brake duct cooling kit install thread. There will many folks wanting to install them with a wide range of expertise. Maybe someone that has already tackled the problem can get it started.
Old Mar 23, 2011 | 02:39 PM
cloud9's Avatar
Well after that thread I'm not sure I want to help
Here's my experience on the kit. Maybe it will be easier/less cutting for you, but this is what we did. My dealer had just installed the same kit on his '11 GT the night before so learned from his experience. We didn't remove the whole front fascia, just the fog lamp inserts.
http://bossmustangsonline.com/boss-3...angsonline/15/
Old Mar 23, 2011 | 02:40 PM
cloud9's Avatar
Yes. You also remove the dust shield because that's what the cooling kit replaces.
Old Mar 23, 2011 | 02:51 PM
cloud9's Avatar
Picked up my car. Busy. It's 30 degrees with a light snow. Broke it in hard (clarification - per Ford's instruction - didn't hold the RPMs and varied speeds). I'll post more later. Initial reaction:
Old Mar 23, 2011 | 03:46 PM
phytrpilot's Avatar
Congrats!!
Originally Posted by cloud9
Picked up my car. Busy. It's 30 degrees with a light snow. Broke it in hard. I'll post more later. Initial reaction:
Congrats Gary!
Old Mar 23, 2011 | 05:36 PM
12C/OBoss's Avatar
Congrats again Gary!!''So with your limited time with the car ...what;s your opinion on the factory exhaust sound?? Would you agree it needs some more rumble out back to match the uncorked sidepipes??
Old Mar 24, 2011 | 08:57 AM
cloud9's Avatar
Well first off, I haven't had an opportunity to hear the exhaust from outside the car while it's moving so somewhat hard to judge. I can see your point about it being too quiet from the back. I'm just not sure what the best solution is if you want it louder. You could put on different axle backs, or you could go off-road X. However, if you go offroad X the side pipes will be too loud and you'd want the discs back in probably, but maybe drilled out some more. I'll wait for you to figure it out and copy it!
Old Mar 24, 2011 | 09:47 AM
12C/OBoss's Avatar
My car is getting tuned next week, along with a catback, and some other top secretparts. Let's just say this car is REALLY going to surprise some people with the numbers it's going to put down N/A
Old Mar 24, 2011 | 10:22 AM
FAST FRED's Avatar
Cool,
can't wait to see the results then.
