2012-2013 BOSS 302
Front end weight - GT500 vs Boss
Old Aug 29, 2010 | 04:02 PM
JonW's Avatar
My last Mustang was an '08 GT500 ragtop. It felt heavy in the front end. Anyone want to hazard a guess about how much weight is on the front wheels of the Boss vs how much weight was on the front wheels of the '08 GT 500 (non-aluminum block)?
Old Aug 29, 2010 | 04:11 PM
2010MustangGT's Avatar
an 08 gt500 conv. was listed as a 57/43 weight distribution. with a curb weight of 4040. So about 2300 at the front and 1900 in the rear. Not to mention how ever much you weight adding into the front proportion making for a 58/42 or so...
I would suspect the Boss to be near 50/50. Probably with a 51/49 or 52/48.
That difference will feel MUCH improved.
EDIT: according to the BOSS' tech specs an estimate from Ford is listed as 55/45 out of 3631lbs.
http://media.ford.com/images/10031/2...Boss_Specs.pdf
Old Aug 29, 2010 | 04:15 PM
Ltngdrvr's Avatar
The boss will be about 1945-1955 pounds on the front.
GT500 with a iron block motor would probably be about 250-300 more.
Old Aug 29, 2010 | 05:11 PM
JonW's Avatar
That's a huge improvement. Thanks for the input guys!
Old Aug 30, 2010 | 05:33 AM
Ranger's Avatar
IMO another important factor is that the Boss' suspension is for road/track
Old Aug 30, 2010 | 07:59 AM
Automagically's Avatar
Not to mention the overall steering improvements the new cars bring. With chassis improvements and EPAS combined, make the new cars much more nimble in the steering department.
Old Aug 30, 2010 | 08:01 PM
MustangFanatic's Avatar
All factors listed should mean the Boss is one nimble performer!
Old Sep 2, 2010 | 12:29 PM
Falc'man's Avatar
The actual difference between the two sans the blower is 104lbs. That's based off the Coyote 5 litre vs the Australian n.a. 5.4, which is the same as the GT500's iron 5.4.
Add the weight of the blower of in the Shelby and you have the actual difference. In total I would say it's closer to 150lbs.
Ecostang
Nov 3, 2022 08:50 PM
Diode Dynamics
Jun 12, 2018 03:26 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
Mackitude
Aug 17, 2015 04:14 PM
