2012-2013 BOSS 302
Which Ford Racing Oil Filter to use ?
Old Jan 28, 2013 | 01:30 PM
PP0005's Avatar
Thinking of having a oil change done to the 12 LS. It has 325 miles on it, but it may be the same oil from the build in Oct 2010.
I was thinking of going with the Ford Racing Filter, any feedback on this filter and which is the correct # for the 2012.
Jason
Old Jan 28, 2013 | 02:00 PM
Brandon302's Avatar
The Boss 302 filter is the FL-500S I believe, I have since switched to the GT500 filter which is the FL-820S after reading a write up by SVTP, no leaks and no issues.
Old Jan 28, 2013 | 02:08 PM
cwcary's Avatar
Hey Brandon302,
Have you got a link to that article handy to post?
Curtis
Old Jan 28, 2013 | 05:04 PM
hori's Avatar
ford racing FL820 on mine.
Old Jan 28, 2013 | 07:51 PM
2012YellowBoss's Avatar
I have done a lot of research into this. The new oil filter correct for the new 5.0 engine is the FL500 and that is what Ford says to use on the Boss.
However - the oil cooler that the Boss has from the factory and is sold as a Ford Racing part for use on the 5.0 GT's - calls for the Ford Racing FL820S.
So technically the FL820S is the correct filter for the Boss. If you are not going to use the racing 820S I would use the FL500 over the regular FL820, since that is what the manual says and they can't argue a warranty claim with that filter on the car in case of trouble.
Old Jan 29, 2013 | 05:49 AM
Brandon302's Avatar
Finally, had to dig deep. http://www.svtperformance.com/forums...d-fl-500s.html
Old Jan 29, 2013 | 07:12 AM
wheelman's Avatar
Installing an oil cooler this weekend on a GT and didn't consider this, so thanks for the heads up.
Old Jan 29, 2013 | 04:34 PM
Berol's Avatar
Using Ford Racing's 820S
Old Jan 30, 2013 | 05:32 PM
PP0005's Avatar
Thanks for all the info !
Ecostang
Nov 3, 2022 08:50 PM
Mackitude
Aug 13, 2015 01:05 PM
MADSCOTSMAN
Jul 22, 2015 04:57 PM
