2012-2013 BOSS 302
FORD Racing LCAs
Old Feb 14, 2012 | 07:50 AM
TMSBOSS's Avatar
FORD Racing LCAs
Has anyone installed Ford Racing LCA
Lower Control Arm Pair, GT500 Style, M-5538-A
LMR amd AM both list them for $134.99.
I am interested in stopping wheel hop and not sacraficing on noise and vibration.
Old Feb 14, 2012 | 08:38 AM
5 DOT 0's Avatar
I think the FR versions you want are the ones from the FR500C.
http://www.fordracingparts.com/parts...KeyField=10918
Old Feb 14, 2012 | 12:27 PM
Tob*'s Avatar
Then stay away from poly bushed LCA's. If NVH is a concern as well as minimizing or eliminating wheel hop - consider the UCA from Roush.
http://www.roushperformance.com/part...2011-2012.html
More on the Roush UCA and bracket here...
http://www.svtperformance.com/forums...roush-uca.html
Old Feb 14, 2012 | 10:20 PM
RJorge1950's Avatar
Hi TMSBOSS,
I was interested in a quality LCA that would not adversely affect NVH on the car and came accros these http://www.spohn.net/shop/2005-2008-...ot-Joints.html ). They are from Spohn and appear to be a viable solution to what you are looking for. I would opt for the chrome moly ones for only $30 more. Let us know what you think.
Rob
Old Feb 14, 2012 | 10:31 PM
TMSBOSS's Avatar
Originally Posted by RJorge1950
Hi TMSBOSS,
Rob
Rob
Thanks for the reply
Looks like a quality part.
I am a little concerned about noise and vibration as well as durability with the Delron lined joint.
Has anyone used this type, or actual unit and what are their Opinions/Results?
All, Thanks for your input!!
Old Feb 15, 2012 | 11:16 AM
06GT's Avatar
Great writeup. I have been considering adding the MM LCAs and wondered about the additional NVH on the street. Sounds like they will be OK.
TO THE THREADSTARTER:
The BOSS already has the GT500 LCAs from the factory.
Old Feb 15, 2012 | 11:27 AM
Tob*'s Avatar
Drew, Jack and the team at MM nailed it with these. I find them to be rock solid and they added no descernable NVH - and I mean that.
Pairing them with the Roush upper turned out to be the perfect combination.
Old Feb 15, 2012 | 05:33 PM
CaptDistraction's Avatar
I'm surprised that the MM ones didn't add a bunch of noise. I could clearly hear a rod-ended panhard bar when I installed it (could hear noise from the differential housing and rear brake moan being transmitted in).
I'm about to try a set of poly bushed arms, but definitely considering that roush upper. We'll see how it goes.
Old Feb 15, 2012 | 08:44 PM
RJorge1950's Avatar
Hi TMSBOSS,
You are welcome !
As far as the durability of Delron all I can tell you is that we use it in the aircraft industry and it's tuff as hell. This is what attracted me to Spohn in the first place. I also like the fact that you can get LCA in chrome moly tubing, saves weight, very strong and we also use it in the aircraft industry. If you like an other brand of LCA that are threaded you can still get just the Delron ends and put them on. I was thinking of doing this to the Steeda upper control arm since I like the Steeda unit but not the spherical end that they have. Good luck with your seach for the right one.
Rob
Old Feb 18, 2012 | 04:58 AM
TMSBOSS's Avatar
Hi TMSBOSS,
You are welcome !
Rob
Still looking.
It will be about 45 days bfore I am back in the states. Plenty of time to fine a quality solution at a fair price.
Old Feb 18, 2012 | 08:50 AM
Tob*'s Avatar
Never heard of Delron before. Are you talking about Delrin? Or does Spohn use some sort of hybrid material?
Old Feb 18, 2012 | 11:08 AM
RJorge1950's Avatar
Hi Tob,
Yes it's Delrin but Spohn Racing calls it a Del-Sphere joint, the material inside is Delrin. Very strong, durable, and self lubricating.
Rob
Old Feb 18, 2012 | 01:44 PM
Tob*'s Avatar
That's a rather bulky joint. In theory - everything sounds plausible. Yet, you are merely sandwiching Delrin between two steel pieces. Clamped together, that thin layer of Delrin does little to dampen frequencies that are transmitted via the suspension arms, pickup points, and ultimately, to the cabin.
The idea of tightening the joint back up as it wears assumes that the wear is concentric and even about the joint. I'll proffer that it is far from that. Certain load paths will compress the Delrin more than others, causing it to thin as it wears. Cinching down the joint at that point only compresses areas with less wear even more. You'd probably be better off switching to replacement Delrin at that point. If the Delrin is the only self-sacrificing part of the joint then I suppose having a supply of them on hand would allow you to keep the original design intention in tact - were they to be of little cost. Yet you still retain the bulkiness of the joint, more so than a heim. The large joint body reduces the angle in degrees to which the joint can articulate as well, given typical OEM bracketry constraints.
I find it easier to just stick with a high quality heim joint that gets replaced in its entirety when wear starts to allow too much deflection.
On edit - don't get me wrong and assume I'm against Delrin. I have Delrin bushed A-arms for my Fox chassis coupe. Much preferred over poly at that juncture for all out performance, but not cheap either.
Old Feb 18, 2012 | 04:03 PM
06GT's Avatar
Tob:
Where are you placing your jack for the rear of the car?
I place the jack pad right on the chassis-side LCA mounting bracket, and while jacking the pad will contact some of the LCA as well. The factory LCA is somewhat of an I-beam design so there's not much to worry about there.
(In your opinion) Is this going to be a problem if I switch to the MM LCAs?
Old Feb 18, 2012 | 06:19 PM
Tob*'s Avatar
You are supposed to be jacking at the dedicated pinch weld area according to Ford documentation...
I jack from underneath the differential, right where Ford tells you not to jack from. I place my stands underneath and outboard on each axle tube. We could go on all day about why Ford doesn't encourage using the points I use and that's fine. I know why they want you to avoid the area I use.
I wouldn't use the bracket you are using but many do and haven't had issue. The factory LCA has a 'taller' body when compared to the MM LCA. So you would have additional clearance with the MM arm should you continue to jack from there...
Old Feb 18, 2012 | 11:15 PM
06GT's Avatar
Been jacking on that bracket many many times w/ my '06 and now the BOSS, no issues, so nevermind what we're SUPPOSED to be doing
I guess I'll just have to see how it works out if I go to the MM LCAs. Worst case I can always get at the pumpkin.
Ecostang
Nov 3, 2022 08:50 PM
SpeedyJoe
18
Aug 23, 2015 02:42 PM
Blown CS
Aug 7, 2015 10:22 AM
