2012-2013 BOSS 302
Clutch Pedal on the floor
Old Jul 10, 2013 | 11:28 AM
yankee_pony's Avatar
I have experienced the 7,000 RPM clutch stays on the floor situation recently.
There also must be a clutch disengagement problem too as shifting would be difficult in the higher operating RPM's
I have flushed the fluid out of the clutch line and replaced it with DOT 4 fluid . Then vacuum bleed the system , which did not alleviate the problem.
I seen this discussed , and the consensus is to remove the "assist spring" .
Has anyone taken the car in to the dealer Under Warranty and reported this problem? Did they have a solution? Did they fix the problem? If yes , what did they do.
Old Jul 10, 2013 | 12:15 PM
jaywoo's Avatar
The removal of the assist spring took care of the problem I had with the pedal sticking to the floor, but not the problem with high RPM shifting. Even the MGW I put in only partially helped with that. I think we just have crappy clutches and transmissions. Nothing that a T-56 Magnum XL and a McLeod clutch on't take care of!
Old Jul 10, 2013 | 10:52 PM
maddog2's Avatar
Oh buy the way the T-56 magnum is about six grand and another thousand for the clutch set up. Ouch
Old Jul 11, 2013 | 06:23 PM
Brandon302's Avatar
Eh it is a little cheaper if you use the JPC swap they have dons, I believe. On the other hand removal of the spring has helped but doesn't fix the issue as some have stated on BMO and here as well. I think people have brought it into dealers and they haven't done much if anything. SVTP's Hybred loved her car but couldn't deal with the issues and eventually bought a CTSV wagon. (so jelly)
Old Jul 15, 2013 | 11:51 AM
ConeBoss's Avatar
You may want to swap the clutch fluid for some higher temp/performance stuff just as a cheap way to see if that takes care of it.
Old Jul 15, 2013 | 02:52 PM
Brandon302's Avatar
DOT 4 should be better then the stock stuff.
Old Jul 17, 2013 | 07:47 AM
DGRacing's Avatar
I only had this pedal sticking problem once. I upgraded to JPC SS clutch line and never experienced it again. But others claim this does not solve it for them.
I also have high temp DOT4. YMMV
PS. I also just got done with the JPC Magnum Conversion kit with RXT clutch....
Old Jul 17, 2013 | 08:47 AM
Brandon302's Avatar
You should post a write up about it.
Old Jul 17, 2013 | 09:03 AM
DGRacing's Avatar
I will. Taking it to VIR this weekend. Will report after that.
Old Jul 25, 2013 | 11:29 AM
JJJTMC's Avatar
Ford Customer Service contacted me after Deysha notified them of my issues with the pedal stayout. Went to the local dealership who was previously contacted before my arrival, they sent notice to Ford engineering in regards to the problem. The old 2011 TSB obviously isn't applicable, however, they are currently aware of the ongoing issue but as of yet no fix is in sight. She stated that the more notices that get sent to Ford engineering, the more likely a fix would come quicker vs later. We shall see .......
Old Jul 25, 2013 | 12:44 PM
FordService's Avatar
Thank you for the update, JJJTMC!
Deysha
Old Jul 25, 2013 | 02:11 PM
ConeBoss's Avatar
Deysha
So here is an aftermarket solution that sounds logical and relatively low cost. Ford racing already has a similar solution they use for the Boss 302S & 302R...maybe they should just make a it a TSB replacement part. (Watch the video.)
http://www.hecticparts.com/products/...TTING-KIT.html
Old Jul 25, 2013 | 02:36 PM
JJJTMC's Avatar
Sweeet video, and does seem logical.
Old Jul 25, 2013 | 03:43 PM
Brandon302's Avatar
Some guys have said the lines do work, others say they don't. I think though after changing the clutch people say these issues go away. Taking the spring off seems to also help, and if done correctly you can always replace it.
Old Sep 26, 2013 | 02:27 PM
RedBoss302's Avatar
I'm experiencing the clutch pedal not coming all the way up with a high RPM shift. Happened twice. I thought I broke something at first.....I've read these post, but has anyone found a cure through a dealer or their own experiments? This really makes a disappointing aspect to an otherwise outstanding car....
Old Sep 26, 2013 | 07:41 PM
maddog2's Avatar
Why is the Ford racing replacement clutch line over $200? I have seen several others for $60 to $100. Is the Ford part better?
Old Sep 27, 2013 | 04:52 AM
RedBoss302's Avatar
Maddog, I'm wondering the same thing. Does anyone have any experence with both? Are they the same?
Old Sep 27, 2013 | 11:04 AM
SoFlaBoss's Avatar
I was in the same position a year ago. This confirms my decision to trade-in my 2012 Boss was a good decision, as engineering was aware of the ongoing issue back then, also with no fix in sight back then. I couldn't enjoy the Boss with the clutch not working above 7K RPM.
Old Sep 27, 2013 | 01:24 PM
Hey RedBoss302,
Welcome to the forum! My name is Deysha with Ford Service and I’d like to get this escalated to the customer service manager for your area. Please, PM me with your VIN, dealer, full name, mileage, and best daytime number.
Deysha
Old Sep 30, 2013 | 07:37 AM
JJJTMC's Avatar
My issue still hasn't been resolved. Waiting on a fix.
