Brake Bleeder for fluid changes
I have not installed them but did order the bleeders. The 33mm is correct for the front but I ordered the 35mm for the rear. That should be correct since the rear is the same as the GT, however until I install them not sure if the shorter ones in the rear will make any difference.
