BOSS Track Use Preparation
Got this off of the BOSS 302 Supplement on myford.com
The Boss 302 and Boss302 Laguna Seca edition have been rigorously proven out on race tracks. Below are recommendations for optimizing your Boss 302 for a track day event.
• For optimal performance, premium fuel is recommended.
• Change brake fluid to Super DOT 4 to improve track performance of braking system (WSS-M6C65-A2), Ford part number (YS4Z-19542-AA).
• Install Ford Racing front brake cooling kit (M-2004-MB) to improve brake cooling (standard on Laguna Seca edition).
• Install Ford Racing transmission cooling scoop (M-5025-MBR) to improve transmission cooling (standard on Laguna Seca edition).
• For extended track use, Ford recommends installing a rear differential cooler to improve rear axle cooling.
• Remove vertical rear tire spoilers at rear edge of rocker moldings.
• The Ford Racing front splitter kit (M-16601-MB, standard on Laguna Seca edition) can be installed to improve high-speed vehicle stability and handling. If the Ford Racing front splitter kit will be installed on a Boss 302 without the Laguna Seca package, Ford recommends installing the Laguna Seca edition rear spoiler in place of the standard rear spoiler to maintain aerodynamic balance. This front splitter is intended for race track use only and is not legal for on-street driving. It may degrade crash performance and void the vehicle warranty. The front splitter must be installed by the customer.
• Depending on track temperature, ambient temperature and driving style, you may need to reduce the starting tire pressure by as much as 4 psi (27 kPa).
• The starting pressure may be lower in the rear tires relative to the front tires to achieve 41 psi (283 kPa) hot.
• Reset tire pressures to placard recommended pressures before leaving the track.
• For improved track performance, Ford recommends, available through Ford Racing. See your local Ford dealer or go to http://www.trackey.ford.com for more information (M-14204-MBTKA).
• Your Bosst 302 is equipped from the factory with Brembo 4-piston front calipers and unique, high-performance rear brake pads that will provide excellent performance under normal driving conditions. Ford recommends the following bedding procedure for race track driving be followed.
Brake burnishing procedure for race track driving
• Fade: 20 fade stops, at 65-0 mph (105-0 km/h), 0.85g deceleration or just below ABS activity, no dwell between stops
• Cool down: Minimum of five mile (8 km) cool down route, if on public roads (no brakes) run at 60 mph (96 km/h)
• Recovery: 30 recovery stops at 60-0 mph (96-0 km/h), 0.4 g deceleration, one mile (1.6 km) between stops
Damper adjustment recommendations:
• Boss302 Laguna Seca edition - Set front dampers to position (5) and set the rear dampers to position (3), (4) or (5) depending on how smooth the track is or how much curbing the driver likes to use.
• On a smooth track with aggressive apex curbs, set the rear dampers to position (4), but only if the driver uses those curbs.
• On a smooth track with mild FIA-type apex curbs, set the rear dampers to position (5).
• If the turn-in portions of the track are rough, reduce the front damper setting by one position until the Boss 302 turns in on those rough portions.
• If the rear of the car is skipping over bumps during corner exit so that the driver has to reduce throttle input, reduce the rear damper setting by one position until the driver can apply appropriate throttle.
TRACK PREPARATION
• Remove rear brake dust shields to improve brake cooling.
• For track sessions, it is recommended to run 41 psi (283 kPa) hot for the OEM tires, front and rear.
Note: Restore the vehicle to factory specifications prior to driving on public roads.
If the vehicle has to be driven on a track (racing) or in severe driving conditions, the following steps must be performed on a closed course, not on public roads:
• Burnish: 30 burnish stops at 60-0 mph (96-0 km/h), 0.4g deceleration, one mile (1.6 km) between stops. If the vehicle has more than 200 miles (322 km) on the brakes, skip this step and proceed to the Fade stops.
• Boss302 - Set all four dampers to position (5) for all tracks.
• On a rough track, set the rear dampers to position (3).
Me too, I can only guess it would make it harder on the line to add different fluid to different cars.
After it says to add DOT 4 for the track it says:
Don't see any sense in that???
i bet they did their testing with dot 3 and they are just doing come CYA. im more interested in why they tell normal boss owners to just run 5 everywhere no matter the track and then recommend all that other stuff for the LS cars. also, that uplevel spoiler will not just bolt right onto the normal boss, it uses a different bolt pattern. i say that assumnign because it looks like the uplevel spoiler you can get in the normal GT appearance package. If it isn't just forget i said that. plus ford also uses copious amounts of 3m style adhevie along with bolts so changing eh rear spoiler out is a hassle.
9/8/15 10:45 AM
