Boss questions
Boss questions
The car cover that comes with the car, is it for outside or inside coverage?
If you install the Steeda springs, does it require caster/camber plates to re-align the front?
I believe when I took a peek at the cover, it was an indoor soft cover
And the steeda springs only bring it down .2" in the front, which negligibly adds negative camber. But for us track guys we want even more camber which is why we add the plates, opposite of others who drop their cars for more show. So, no you will not need to add them, the alignment will come to spec... On the other hand you may want to add the panhard bar to realign the rear that drops .7". Still negligible but worth it more than the plates to re-spec your alignment
You dont have to get plates unless you want to change camber. Your front alignment should end up nearly identical to what you started with because the front ride height barely changes if you are installing these on a Boss.
A panhard bar is not required. We recommend it due to the reduced deflection from our bushings and it takes a few pounds of weight off the car as well.
Ride height changes 0.2 inches in the front, and 0.7 to 0.8 inches in the rear.
Give us a call if you have any additional questions.
TJ
TJ
Evil_Capri
9/11/15 08:39 AM
