Boss Gear calculator / Tire Fitment Simulator
Here's a screen shot of a gear calculator I came accross a while back.
I modded it for the Boss. The calculator is attached in the zip file below.
You will need Excell for this...........
Have fun.
Yes I know the car is limited to 155 MPH and is not capable of 200+ MPH............
Have fun.
Can you change it to an older Excel version? You have it saved under 2010 .xlsx
oh, and the tire data is not factory, just for those looking at the results.
Thanks,
Dave
Thanks,
Dave
Here is an Excel 2007 version (I hope it attached)
Added a 97-2003 verison
Added this info the spreadsheet so you have it.........
2012 Boss 302
Front wheel specs:
19" x 9" wide
5-lug, 4.5" bolt circle
169.3mm backspacing
42mm offset
255/40R-19 Pirelli PZero max performance
Rear wheel specs:
19 x 9.5-in.
180.9mm backspacing
45mm offset
285/35R-19 Pirelli PZero max performance
2012 Boss 302 Laguna Seca
Front wheel specs:
19" x 9" wide
169.3mm backspacing
42mm offset
255/40ZR-19 Pirelli Corsa competition performance
Rear wheel specs:
19" x 10" wide
187.5mm backspacing
47.5mm offset
285/35ZR-19 Pirelli Corsa competition performance
What type of Calculator would I use for this issue:
I ran my Boss with 28" DR and had plenty of rpm left in 4th gear to finish the 1/4 mile. @114.5
Today I installed 26" DR and took it on (Closed Coarse
) and ran it to the rev limiter to see if I can use them in the 1/4 without going into 5th.
I was able to reach 120 mph @7500 in 4th gear,
My question how do I find out what the actual speed my car was traveling? Speedometer said 120 But Im sure it was off because Stock tire size is 27 1/4
4th gear 1:32:1
Axel ratio 3:73
wheel size 26
rpm 7500
) and ran it to the rev limiter to see if I can use them in the 1/4 without going into 5th.I was able to reach 120 mph @7500 in 4th gear,
4th gear 1:32:1
Axel ratio 3:73
wheel size 26
rpm 7500
roushcollection
Jul 28, 2015 02:08 PM
