2012-2013 BOSS 302
Boss cowl piece?
Old Jul 20, 2012 | 02:28 PM
JPC's Avatar
JPC
Boss cowl piece?
I attached a couple pictures from my Boss this AM
....everyone's Boss is like this... and I bet all 2011+ Mustangs too.
I wonder if we can REMOVE or CHANGE this big black lower cowl that we can improve air flow OUT of the hot engine bay.
Anyone try anything like this before?
Old Jul 20, 2012 | 02:34 PM
ShaneGT's Avatar
never noticed that.. good find... should be a direct replacemnt if you can get the PN.
Old Jul 20, 2012 | 07:24 PM
ford20's Avatar
I remember someone saying that they removed this and that it did in fact reduce underhood temperatures along with the Boss 302S Grill.
Old Jul 21, 2012 | 02:50 AM
TMSBOSS's Avatar
If this is removed would it not increase under hood pressure/air?
Cowl induction hoods have this area open and the effect is an increase in airflow, air flowing into the engine compartment,at the rear of the hood. The cowl is a high pressure area caused by the air stacking up while making the turn upward and over the glass.
So would the desired effect be achieved, additional airflow outward from under the hood if this area were modified? The opposite may occur.
Old Jul 21, 2012 | 05:39 AM
jim woodruff's Avatar
Some owners have just removed the rubber seal at the top which seals the hood to the plastic lip of the cowal
Old Jul 21, 2012 | 05:18 PM
BLAZN BOSS's Avatar
The statement about the cowl induction hood is right. This is a very low air pressure area and is optimum for the intake (carburated) to get cool clean undisturbed air. There is not enough air flow suction here that suffices to remove engine temps.
Old Jul 22, 2012 | 05:09 AM
Resolution78's Avatar
wonder if that changes with a tiger racing hood
Old Jul 22, 2012 | 06:19 AM
BLAZN BOSS's Avatar
No because your getting the air over the forward center of the hood.......absolutly getting the siphon effect at that area.
Old Jul 22, 2012 | 03:49 PM
908ssp's Avatar
Correct. Removing the gasket or worse the cowl cover won't help when the car is moving. See those slots in the cover? That is where the air gets in for your heater.
May 3, 2026 05:42 AM
Mr. V
Dec 24, 2016 02:57 PM
Cobiecane
Oct 23, 2015 08:44 AM
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
