2012-2013 BOSS 302
Boss Air Conditioning Not Cold Enough,...
Old Jul 21, 2013 | 04:40 PM
jouster's Avatar
Hi,
My 2012 Boss with only 6000 miles on it is blowing 'cool air' but not 'cold air' with th A/C on.
Has anyone had the same problem?
It's pretty early in this car's life to be adding a can of refrigerant, but that's my next step,... unless someone has a better solution.
Cheers,
Old Jul 21, 2013 | 06:20 PM
69mustangman's Avatar
I have 20k on my 2012 and it just started blowing cool/warm air on the drivers side. Passenger side blows cold air. Seems to be intermittent. Going to take it in this week.
Old Jul 22, 2013 | 08:56 AM
TMSBOSS's Avatar
Take it to the dealer. Have it fixed and document the problem as being there before the warranty runs out.
Old Jul 22, 2013 | 09:08 AM
topbliss's Avatar
I've owned 2 new cars that were low from day one. Added refrigerant and all is fine years later.. You ARE using the 'recirc' setting when its really hot out aren't you? My father in law never knew about this setting since 08 with his GT. Since I told him about it he is happy
Old Jul 22, 2013 | 09:14 AM
RedCandy5.0's Avatar
My '13 Explorer just started blowing hot air out of it with less than 10k on it. Going in tomorrow.
Old Jul 22, 2013 | 11:04 AM
bigbossman's Avatar
My compressor locked up at 30K (melted junk spewed everywhere), replaced under warranty.
Old Jul 22, 2013 | 02:14 PM
JeffL's Avatar
I've been thinking the same. 20k miles on mine. it's has been 95+ for over a week now so maybe the heat is just getting to me. getting an oil change on friday will mention it.
Old Jul 22, 2013 | 06:10 PM
denlem's Avatar
My GT is not very cold when it's very warm out. It was in the 90's and humid all last week and I was comfortable but not very cold. Took a while to cool down too. If the sun was behind clouds it seemed better. On 80º days and less humidity it works better. Cold, but not freezing as i've had in other cars.
Old Jul 22, 2013 | 08:54 PM
Fenderaddict2's Avatar
Though mine was weak due to the heat but both my Mazda 2 and Dodge Journey coped well enough so the Boss is going in to have the AC looked at.
Old Jul 23, 2013 | 03:48 AM
wannabe's Avatar
I was disappointed I the A/C in both my '10 and '12.
Old Jul 23, 2013 | 08:00 AM
FordService's Avatar
Originally Posted by jouster
Hi,
Hi guys,
I recommend you get them checked out at your dealer and speaking to your Service Manager about this. He/She is in the best position to look into this for you. He/she can check into any warranty, assistance, recalls, or Customer Satisfaction Programs that may apply to your vehicle. Let me know the outcome.
Deysha
Old Jul 23, 2013 | 12:14 PM
Brandon302's Avatar
Doing Max A/C when it is above 90 is basically needed, otherwise it cannot cool the air enough it seems.
Old Jul 23, 2013 | 01:01 PM
I go in Wednesday. Feeling its a blend door problem. Very little explains cold on passenger side and warm on drivers side. Will know tomorrow and will advise.
Old Jul 23, 2013 | 04:10 PM
Ssgthooligan's Avatar
My '13 Track pack is doing the same. Plus I've got a tick coming from under the car.
Old Jul 23, 2013 | 05:58 PM
Fastoldman's Avatar
Hmmm.... appreciate this post as have been having the same issue with mine at around 16K. My other cars freeze me out and though eventually it gets cool, it takes an inordinate amount of time. Good to know others have noticed this - thanks!
Old Jul 23, 2013 | 07:31 PM
PonyMuscletang13's Avatar
Good to know I'm not the only one. This week's been pretty hot here in SoCal, although I remember last summer when I just bought the car, the a/c felt cooler.
The window tint does help blocking the heat from direct sunlight, but now I know generally the Mustangs do get warmer than other cars in the cabin.
After all, we are driving American Muscle aren't we?
Old Jul 23, 2013 | 09:17 PM
Grant 302's Avatar
Also in SoCal here, and I think my A/C is working okay. But my understanding is that the compressor doesn't run when on the throttle or past a certain amount of throttle. So I know if I do a bunch of stoplight to stoplight WOT runs, then I expect the car to get warm inside...
Old Jul 24, 2013 | 10:16 AM
Originally Posted by Fastoldman
Hmmm.... appreciate this post as have been having the same issue with mine at around 16K. My other cars freeze me out and though eventually it gets cool, it takes and inordinate amount of time. Good to know others have noticed this - thanks!
Hi guys,
I spoke to my Technical Specialist and as Grant 302 mentioned, he advised there are quite a few things that will make the compressor cut off. Some are normal characteristics to make sure it does not burn out and some that could be concerns. I recommend you bring it to your Ford dealers and have them check it out to make sure all is good. Please let me know the outcome.
Deysha
Old Jul 25, 2013 | 05:04 AM
BOSS MAN 13's Avatar
So far, so good for me, my '13 blows ice cold. I've been lucky with Ford AC so far, my 2010 Fusion is frosty, and my '04 Super Duty diesel and '05 Escape have never been touched, each has over 130k miles on them!
Old Jul 25, 2013 | 09:00 PM
Well, problem solved. Problem was low refrigerant. Topped it off and she's blowing cold again. They put dye in the system to find the leak but after a day of searching there wasn't one. Can't explain where it went but if it leaks at least they will be able to find it. So now I can enjoy hot summer days in comfort while traveling.
