2012-2013 BOSS 302
Boss 302 QTP Electric Cut Outs
Old May 28, 2012 | 10:15 AM
steve03gt's Avatar
Anyone here bought them? Where did you buy them, their online store has been closed forever, I can't find this product anywhere else
Old May 28, 2012 | 03:46 PM
MoscowBoss's Avatar
Just call them directly.
Old May 28, 2012 | 08:25 PM
2012YellowBoss's Avatar
A friend of mine has the QTP cutouts for sale for $300, used a couple of months.
Old May 28, 2012 | 08:29 PM
steve03gt's Avatar
I'd be interested if they were a bit cheaper, since I'd still have to ship them, for an extra 50 bucks I can have brand new
Old May 29, 2012 | 06:53 AM
chief_charlie's Avatar
Scott
The bigger question is why did your friend remove them...after all the effort to install them?
I've got a set on the shelf and still pondering whether to put them on the car...................
Old May 29, 2012 | 07:32 AM
Originally Posted by chief_charlie
Scott
He is selling the car to build a race car. He had done a few mods to it, springs, camber plates etc but figured it best to restore the LS to factory for the sale.
Old May 29, 2012 | 07:44 AM
Thanks Scott
Old May 29, 2012 | 08:08 AM
OffensiveDriver's Avatar
Scott
I highly recommend installing them. When installing them, it became clear the side dumps had been designed with the electric cutouts in mind.
I run them wide open around town with the Ford Racing touring mufflers and the sound is absolutey incredible-not too loud (I get a lot off people on the street actually turn and admire the car). Butt dyno says awesome.
The cutouts are "infinitely" variable so you can adjust them as much as you want and can even turn them off to go stealthy.
No reason to cut your shift boot, I fed the wires up through the emergency brake cable grommet. The grommet is a soft foam and I fed the wires in between the body and the foam ( I used a long zip tie because it's flat and won't damage the grommet) then cut the wires to length and soldered them. I mounted the switch in the easily replaced aux mini jack plate in the center storage compartment.
Highly recommend.
Old May 29, 2012 | 10:25 AM
PM Sent with questions Thanks
Highly recommend.
fhr.boss302
Aug 9, 2015 07:09 PM
tdf017
Aug 5, 2015 10:13 AM
Sacmus
Jul 22, 2015 02:59 AM
