2012-2013 BOSS 302
Boss 302 / LS Product Info
Old Jan 7, 2011 | 06:27 PM
cloud9's Avatar
Originally Posted by PTRocks
From the article that I posted one of their main considerations was to avoid damaging the cats. Running too lean can cause the temps to rise to high. Leaning out the mixture results in more power, which is probably where some the aftermarket gains come from.
Some tuners will turn off catalyst over-temperature enrichment to achieve this. If the vehicle doesn't have an off-road X pipe you can end up with fried cats.
I think there are good tuners that will dial in a "safe" tune, but the real question still comes down to whether the gains are worth the expense and risk. It will be great when we start getting our cars and can see some dyno charts showing the torque and hp curves.
Old Jan 7, 2011 | 06:29 PM
cloud9's Avatar
Originally Posted by Tony Alonso
Is not the stock engine's intake system considered a closed cold air intake?
I have not heard of that. Can you point me to the info on that Tony?
Old Jan 7, 2011 | 06:53 PM
karman's Avatar
Unhappy
Originally Posted by karman
The important thing to remember is that by calling it a "TracKey" it is specified for track use only and not EPA certified.
That means it is a way better tune than stock and being Ford made it shouldn't hurt the car to use it.
Originally Posted by cloud9
That's not true. If you read all their literature, it's emissions compliant, just like all of their tunes. I've had a few FRPP tunes and they even issue a CARB certificate with them.
Sorry.
I guess I misstated that.
What I meant was by "EPA certified" was that it was not considered in the CAFE mileage requirements.
I meant the tune will not get as good gas mileage, but as a track car it doesn't matter.
I still believe this is part of the reason for the TracKey or else all Boss 302s would have a race tune.
C'mon the Boss 302 and Boss 302 LS are really kinda race cars.
They should come tune like that without a special key.
Old Jan 7, 2011 | 07:19 PM
2012YellowBoss's Avatar
I really like the idea, besides the "Wow" factor it will be nice to take an easy drive to the track with one key then change it.
I know it is not a drag car but I am interested in the 1/4 times between the two keys. Can't wait to try.
Old Jan 7, 2011 | 09:27 PM
Tony Alonso's Avatar
The words are printed on the air filter box
This intake set-up was first seen on the 2010 4.6L V8s and advertised by Ford as the factory configuration for ducting cooler air from the front grille into the flow path to the manifold.
A version of this was designed for the 2011 5.0L engine in the GT.
Old Jan 8, 2011 | 08:52 AM
cloud9's Avatar
Oh cool. I hadn't seen that. If you go to the FRPP site, they have CAIs for the 05-09 Mustang GTs, but the 2010+ just include a ProCal tuner and a K&N high flow air filter. I wonder if we can just drop in a K&N high flow filter (or need to) with the TracKey tune?
Old Jan 8, 2011 | 02:11 PM
bfit's Avatar
Thanks for the additional product info!!!!
May 3, 2026 05:42 AM
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
boz
Oct 1, 2015 04:47 PM
GLOCKer
Sep 28, 2015 05:20 PM
