Any updates to TracKey software?
Wondering if Ford has updated the software for TracKey. My lopey idle is still not where I think it should be.
Trac Idle will kick on once engine warms up but it seems to stop working after I've been driving it for a bit.
I have no accessories running.
Don't understand why it goes away.
Mine seems more pronounced when its warm, I doubt Ford will change it due to the Catalytic Converters.
My key flash fine as well. Word to the wise as far as the 36K warranty though--checked with the Ford Racing tech line today and they didn't have any record of my warranty/purchase yet. Had to call the dealer and ask them to send FR a bill of sale from the TracKey purchase and a copy of the work order. You may want to call and make sure your warranty is in effect.
Could you just go back and get reflashed at the dealer?
I also wonder if the 2013 Boss flash is any different than the 2012.
![Th Smiley Salute](https://themustangsource.com/forums/images/smilies/th_smiley_salute.gif)
You can also verify if the trackey is working properly by going into the pit mode setting and if the green light flashes once you are in the setting, then the trackey flash is good.
Go to the website:
http://www.trackey.ford.com/trackey
Click on:
TracKey Dealer Instructions V1.3 Installation Patch for Dealers
Read question and answer on top of page 11 regarding your issue.
What if the " TRACKEY IDLE / ENGINE ENABLED" message is displayed but the idle is not very lopey?
This instruction indicates that "the PCM may need to relearn the zero (or "home") position of the cams." Follow the procedure to reset. Let us know if this works for you.
VA Boss
Click on:
VA Boss
Go to the website:
Click on:
VA Boss
Click on:
VA Boss
I reset the cam zero as instructed.
Too early to tell if it made a difference. Previously I had the lopey idle but it would smooth out after I had been driving it for a bit.
Today I did the reset and then used the Red Key, the lopey idle was there but I didn't take the car out for a test run.
So I'll see what happens next time I've driven the car for a bit.
Hey folks! Particularly Whammer - I found this very interesting on another competing Mustang forum. I'm not sure if I can link this without get the forum moderator pissed at me. Anyway - check out this interesting even if it is slightly dated. Go to:
http://www.boss302forum.com/index.ph...rding-trackey/
If this works for anyone here, please post to let us know if these recommendations worked for you. I'm very interested to know.
VA Boss
VA Boss
![Bs](https://themustangsource.com/forums/images/smilies/bs.gif)
Ford has never claimed an increase in HP so don't expect any. I don't believe a word of what that guy posted.
Considering how clueless dealers are about the TracKey, no. It's not going to gain or lose any features. Any updates are going to be purely bug fixes for particular circumstances. They have your money and the regulatory hassle to get it done in the first place was pretty large. They're not going to go fiddling with it if they don't have to.
