Add 2 deg timing with race fuel ?'s
Hi,
I'm running only 100 octane race fuel in my '12 Boss 302. My tuner said he enabled options for me to add 2 degrees of timing. And said it will add power.
Has anyone done this? What are the side effects (good and bad)?
thanks.
thanks.
Not much of a tuner but I have read something online so I might be able to help. I believe from MotoIQ they stated that adding timing is generally a bad idea. But I could be wrong, read for yourself http://www.motoiq.com/MagazineArticl...ng-basics.aspx
Thanks Brandon. Yeah, I'm torn. Some say its safe to add 2 degrees when running 100 octane.
I will be doing some dyno pulls after my crank relearn yesterday to see if it holds at WOT and wondered if its a good time to add timing with the race fuel.
I may not want to tinker too much this time around.
roushcollection
7/28/15 02:08 PM
