2012-2013 BOSS 302
2012 BOSS LS WON'T START SOMETIMES
Old 1/8/23 | 02:29 PM
shelbygt350s's Avatar
HI Have a friend that has a low mileage 2012 Boss 302LS sometimes it won't start like it has a dead battery wait a bit starts right up the other day we took it out and when we got back . pulled into drive way it died and again nothing we waited and finally started i put a scanner on it no codes anyone have any ideas thanks it does have a new battery
Old 1/8/23 | 02:53 PM
05stangkc's Avatar
The Analog Admin!
Just For Giggles Clean the Battery Terminals & Cables Again. I have Had Some That Looked Kitty Clean but a Film on the Connections would Make it act Dead! What you Got to Lose!
KC
Old 1/8/23 | 10:08 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
I've had issues like this before, even with a new battery. Only description I've ever used is a "dead cell" in the battery. Crank a hundred times in row, then won't hit a lick at all. And like KC said, check and clean all connections and check grounds. Sand them and tighten well.
If it quit while running, you've got some other issue. If the alternator is putting out properly to the system, you should basically be able to take the cable off the battery and it still run, the battery just starts it and the alternator runs everything after it's running and just keeps a surface charge on the battery.
Old 1/9/23 | 07:11 AM
Bert's Avatar
I'll buy it from him cheap if he wants to get rid of it! :-)
but seriously, I would also start with the battery ... if it's the original battery, I'd be taking a ride to Walmart for a new one without a second thought
Old 1/9/23 | 03:31 PM
m05fastbackGT's Avatar
Also, If this vehicle isn't operated for prolonged periods? you may also want to consider connecting a battery tender which keeps the battery fully maintained and charged...
yellow98cobra.com
2012-2013 BOSS 302
7/20/13 06:40 AM
MAD MAN
2012-2013 BOSS 302
9/5/12 12:03 PM
SoFlaBoss
2012-2013 BOSS 302
21
2/13/12 06:28 PM
VALCAD
3/11/11 01:33 PM
Quick Reply: 2012 BOSS LS WON'T START SOMETIMES
